Not able to visualize orientation with Quaternions in vtu files
I am trying to visualize orientation of spherical particles. I have vtu files which has 4-component Quaternions in it, as can be seen in the screenshot. (or see the file: config_t90.vtu (1.3 KB) )
However, I am not able to properly visualize the orientation/rotations using it - it doesn’t change. I am using 3D Glyph for Representation, using Sphere as Glyph Type, Quaternion as Orientation Mode, and column “Quaternion” as Orientation vectors, etc.
Glyphs also looks really large in size. Setting radius and Scale Factor to 1.0 in Properties tab alone does not give true size. But setting raidus = 0.005 (true radius of particle in meter) in Display(GeometryRepresentation) tab makes it closer to true size. But still the overlap sometimes and is not perfect. What am I doing wrong here? Here is my state file for the same file : state_file.pvsm (296.0 KB)
Hi @pfahd
Orientation (with a quaternion or otherwise) on a sphere won’t give you anything interesting, it only make sense if you have a dinstinct shape.
Here is how it looks with a quaternion oriented cube:
Regarding the scaling, well it depends on your data. I’d assume you need a
  • Scaling=True
  • ScaleMode=Magnitude
  • ScaleArray=Radius
  • ScaleFactor=1
Hi @mwestphal , thank you for your reply. Is the image you generated using the data I shared? could you share the script please?
And about the sphere orientation, ParaView can actually do that. We just need to make low resolution Glyph. See an example below (here I used a vector to specify orientation)
test2
Another way is to color Glyph in different directions with different colors. See an example in my previous post. And about the scaling, when I use ScaleFactor=1, spheres are so big that they overlap each other. I am able to reproduce this still, using the same samples configuration files I shared. So, somehow my data needs a smaller value.
Here it is:
boxes.py (4.9 KB)
And with spheres:
spheres.py (4.9 KB)
Thanks a lot, it works perfectly!
I think the missing part was not using the filter ConvertToPointCoud. I have been doing the normal Glyph directly to the data. And again, using low resolution in Glyphs, I can see the rotation as expected!
WorkingQuat
Meanwhile, I had also got it partially working. Problem was, running the ParaView version I compiled locally ‘Orient’ button ( dg ) was not visible. Downloading the binary directly, fixed it, among many other weird things I had.
However, it was doing something weird. For the sake of understanding, could you please comment on what was happening there? i.e., applying Sphere Glyph, and changing/ introducing 3D Glyph only in Display (GeometryRepresentation) tab as: (that is by not doing ConvertToPointCould filter)
It produces something like below.. what is happening here? it looks like many small spheres combined. Otherwise, thank you again.
WorkingQuat3
Simple, do not use the “Glyph” filter, but use only the 3D glyphs representation.
oh! But shouldn’t I first apply filter ConvertToPointCloud then?
I tried selecting it directly under Display tab, and it shows nothing.
Like in the screenshot below:
What you see in pipeline is freshly loaded vtu files.
Just trying to understand how one can do it from the user-interface in proper way.
Yes, you should.
