Hello everyone
I built ParaView v5.7 with the superbuild, EGL, cuda and mpi enabled for a cluster with V100 GPUs. For now it should just run on one node with one V100.
When I connect to ParaView with a client and create a wavelet, it works just fine. When I load the Index Plugin and then create a wavelet, ParaView crashes with the following output.
Thank you very much for help in advance!
Edit: Must be a cuda driver issue. When i run deviceQuery from the cuda samples, I also get the message “CUDA driver version is insufficient for CUDA runtime version”.
Edit2: I fixed the driver issue, deviceQuery has a proper answer now but ParaView with Index still fails.
Edit3: Maybe it is worth mentioning that is used the following files for the EGL build. I found them few weeks back, can’t find the source of the information anymore. But the build only works with them.
https://www.khronos.org/registry/egl/api/EGL/egl.h
https://www.khronos.org/registry/egl/api/EGL/eglext.h
https://www.khronos.org/registry/egl/api/EGL/eglplatform.h
