Hi guys,
I’m being dumb. I just downloaded the Linux version of 5.5.2, and cannot see where the setting is to turn offscreen rendering on. Did it go away, and if so, why?
Thanks all,
Alan
Hi guys,
Thanks all,
Alan
See this.
Following is the extract from Default Rendering Modes section.
–use-offscreen-rendering command line option supported by ParaView 5.4 and earlier has now been deprecated and is interpreted as --force-offscreen-rendering.
Hope that clarifies things.
Greatly, well, somewhat. Two follow-on questions:
It’s on the ParaView Doxygen page here. Feel free to suggest where it should be linked to.
I don’t follow. What was the user doing previously? Was the user was using --use-offscreen-rendering on pvserver? If so, you don’t need to add any optional at all. It will be do offscreen by default. You can add --force-offscreen-rendering just to be safe, but not needed.
Lets say a user is running built-in server ParaView. Say said user wants to make movies. Say as these movies are being build, the screensaver comes on. Will the movies be of the visualization, or the screensaver? Second, if the user wants to make movies of a higher resolution, will this work?
Unless something has changed in the last 5 years, they will be corrupted or of the screen saver. I remember doing this in grad school and having to disable my screen saver because it corrupted the video ParaView was saving. Given that we still disable screen savers on dashboards so the image comparisons work, I’m going to say it will still corrupt the images.
Exactly. That’s why the Settings/ Rendering/ Use Offscreen Memory for Screenshots existed. And, now it appears to be gone…? This is important functionality for my team.
ANSWERED. I talked to Utkarsh, then did a little testing. The flag that use to be in the Settings area, which forced Use Offscreen Rendering For Screenshots is no longer needed. ParaView will use offscreen rendering for the client (built-in server) correctly and by default. In other words, making movies will work correctly even if the screen is screenlocked. It will also correctly make screenshots and movies that are larger than the current Rendering View.
