Hi, I am trying to open a Tecplot file .dat in attachment through ParaView 5.4.1.
It is a sphere with triangular mesh and it is printed by the CFD solver with datapacing=block and with a varlocation=cellcentered formats.
By searching in the web I found that a first possible step is to remove the line of the TITLE, as done for the other attached files momentum_0; but unfortunately it doesn’t work.
The main difference between the two files is the format of momentum_0 which is datapacking=point, thus in each line there are all the variables for each nodes; but I cannot modify the printing setup in the CFD solver.
Do you know if there is a way to open this Tecplot file type with datapacing=block and varlocation=cellcentered formats through ParaView? I also tried to use the Cell Center filter.
Thank you in advance,
Gianluca
momentum_0.tec (33.3 KB) momentum_0_modified.dat (33.2 KB)
sfera.gts01_00005.dat (1.6 MB)
