I can build Demo0, Clone1 and Clone2. But when building Demo1 and Demo2 I get these errors:
( 2.505s) [paraview ] vtkShaderProgram.cxx:439 ERR| vtkShaderProgram (0x7fb8b448c4d0): ERROR: 0:1: '' : version '150' is not supported
( 2.505s) [paraview ]vtkOpenGLPolyDataMapper:2581 ERR| vtkOpenGLPolyDataMapper (0x7fb8b108b000): Could not set shader program
( 2.505s) [paraview ]vtkOpenGLPolyDataMapper:2593 ERR| vtkOpenGLPolyDataMapper (0x7fb8b108b000): failed after UpdateShader 1 OpenGL errors detected
0 : (1282) Invalid operation
( 2.506s) [paraview ] vtkShaderProgram.cxx:438 ERR| vtkShaderProgram (0x7fb8b5004ed0):
( 2.509s) [paraview ] vtkShaderProgram.cxx:439 ERR| vtkShaderProgram (0x7fb8b5004ed0): ERROR: 0:1: '' : version '150' is not supported
( 2.509s) [paraview ]vtkOpenGLPolyDataMapper:2581 ERR| vtkOpenGLPolyDataMapper (0x7fb8b208c000): Could not set shader program
( 2.509s) [paraview ]vtkOpenGLPolyDataMapper:2593 ERR| vtkOpenGLPolyDataMapper (0x7fb8b208c000): failed after UpdateShader 1 OpenGL errors detected
( 2.510s) [paraview ] vtkShaderProgram.cxx:438 ERR| vtkShaderProgram (0x7fb8b448c4d0):
( 2.510s) [paraview ] vtkShaderProgram.cxx:439 ERR| vtkShaderProgram (0x7fb8b448c4d0): ERROR: 0:1: '' : version '150' is not supported
( 2.510s) [paraview ]vtkOpenGLPolyDataMapper:2581 ERR| vtkOpenGLPolyDataMapper (0x7fb8b208c600): Could not set shader program
( 2.510s) [paraview ]vtkOpenGLPolyDataMapper:2593 ERR| vtkOpenGLPolyDataMapper (0x7fb8b208c600): failed after UpdateShader 1 OpenGL errors detected
( 2.512s) [paraview ] vtkShaderProgram.cxx:438 ERR| vtkShaderProgram (0x7fb8b448c4d0):
( 2.513s) [paraview ] vtkShaderProgram.cxx:439 ERR| vtkShaderProgram (0x7fb8b448c4d0): ERROR: 0:1: '' : version '150' is not supported
( 2.513s) [paraview ]vtkOpenGLPolyDataMapper:2581 ERR| vtkOpenGLPolyDataMapper (0x7fb8b108b600): Could not set shader program
( 2.513s) [paraview ]vtkOpenGLPolyDataMapper:2593 ERR| vtkOpenGLPolyDataMapper (0x7fb8b108b600): failed after UpdateShader 1 OpenGL errors detected
( 2.514s) [paraview ] vtkShaderProgram.cxx:438 ERR| vtkShaderProgram (0x7fb8b5004ed0):
( 2.515s) [paraview ] vtkShaderProgram.cxx:439 ERR| vtkShaderProgram (0x7fb8b5004ed0): ERROR: 0:1: '' : version '150' is not supported
( 2.516s) [paraview ]vtkOpenGLPolyDataMapper:2581 ERR| vtkOpenGLPolyDataMapper (0x7fb8b208c000): Could not set shader program
( 2.516s) [paraview ]vtkOpenGLPolyDataMapper:2593 ERR| vtkOpenGLPolyDataMapper (0x7fb8b208c000): failed after UpdateShader 1 OpenGL errors detected
( 2.517s) [paraview ] vtkShaderProgram.cxx:438 ERR| vtkShaderProgram (0x7fb8b448c4d0):
( 2.518s) [paraview ] vtkShaderProgram.cxx:439 ERR| vtkShaderProgram (0x7fb8b448c4d0): ERROR: 0:1: '' : version '150' is not supported
( 2.519s) [paraview ]vtkOpenGLPolyDataMapper:2581 ERR| vtkOpenGLPolyDataMapper (0x7fb8b208c600): Could not set shader program
( 2.519s) [paraview ]vtkOpenGLPolyDataMapper:2593 ERR| vtkOpenGLPolyDataMapper (0x7fb8b208c600): failed after UpdateShader 1 OpenGL errors detected
( 2.520s) [paraview ] vtkShaderProgram.cxx:438 ERR| vtkShaderProgram (0x7fb8b448c4d0):
( 2.521s) [paraview ] vtkShaderProgram.cxx:439 ERR| vtkShaderProgram (0x7fb8b448c4d0): ERROR: 0:1: '' : version '150' is not supported
( 2.521s) [paraview ]vtkOpenGLPolyDataMapper:2581 ERR| vtkOpenGLPolyDataMapper (0x7fb8b1072200): Could not set shader program
( 2.521s) [paraview ]vtkOpenGLPolyDataMapper:2593 ERR| vtkOpenGLPolyDataMapper (0x7fb8b1072200): failed after UpdateShader 1 OpenGL errors detected
( 2.554s) [paraview ] vtkOpenGLState.cxx:930 WARN| Error glActiveTexture1 OpenGL errors detected
( 2.581s) [paraview ] vtkOpenGLState.cxx:930 WARN| Error glActiveTexture1 OpenGL errors detected
( 2.590s) [paraview ] vtkShaderProgram.cxx:438 ERR| vtkShaderProgram (0x7fb8b42b6d60): ( 2.590s) [paraview ] vtkShaderProgram.cxx:439 ERR| vtkShaderProgram (0x7fb8b42b6d60): ERROR: 0:1: '' : version '150' is not supported
( 2.590s) [paraview ]vtkOpenGLVertexArrayObj:266 ERR| vtkOpenGLVertexArrayObject (0x7fb8b42b6fc0): attempt to add attribute without a program for attribute ndCoordIn
( 2.590s) [paraview ]vtkOpenGLQuadHelper.cxx:71 WARN| Error binding ndCoords to VAO.
vtkMemberFunctionCommand<vtkSMViewProxyInteractorHelper>::Execute(vtkObject*, unsigned long, void*) + 288
( 2.590s) [paraview ] :0 FATL| Signal: SIGSEGV
[1] 38231 segmentation fault ./DemoApp1
