A post-processing script I made redefines a variable that may be wrongly defined by my solver. However, this value depends on an other scalar also present in the dataset.
I initially tried to do this using the calculator filter:
if(scalar2<0.8,50*scalar3,6000*scalar3)
But I turned out that the variable created may disappear from the dataset … (I have to report this bug)
So I tried to do that using a programmable filter, but I am getting stuck when I want to overwrite the values in the array. My dataset is usually a multi-block dataset and this seems not to be helping.
here is the script I used so far:
import vtk
import vtk.numpy_interface.dataset_adapter as dsa
import vtk.numpy_interface.algorithms as algs
import numpy as np
data = dsa.WrapDataObject(inputs[0])
scalar1 = data.CellData["scalar1"]
scalar2 = data.CellData["scalar2"]
scalar3 = data.CellData["scalar3"]
newArray = scalar1 * 0
for i, val in enumerate(scalar1):
if scalar2[i] < 0.8:
newArray[i] = 50*scalar3[i]
else:
newArray[i] = 6000*scalar3[i]
output.CellData.append(newArray, 'newVal')
This obsvioulsy fails. Partly because my “newArray” is a composite array…
I made another check: merging all the blocks together. and this leads to the expected result!
So there seem to be something going on with multi-block datasets.
Ah, indeed. The usual numpy functions do not work for VTKCompositeDataArrays that are available from multiblock datasets, but the numpy-like algorithms provided by vtk.numpy_interface.algorithms do. However, the where function provided in vtk.numpy_interface.algorithms is only the single-argument version, not the three-argument version I suggested, so merging the blocks is the only way to use this numpy expression currently.
Here’s a way to fix your Python Programmable filter script to work with composite arrays:
import paraview.vtk.numpy_interface.dataset_adapter as dsa
import paraview.vtk.numpy_interface.algorithms as algs
import numpy as np
cd_scalar1 = data.CellData["scalar1"]
cd_scalar2 = data.CellData["scalar2"]
cd_scalar3 = data.CellData["scalar3"]
cd_newArray = cd_scalar1 * 0
for scalar1, scalar2, scalar3, newArray in zip(cd_scalar1.Arrays, cd_scalar2.Arrays, cd_scalar3.Arrays, cd_newArray.Arrays):
# you may check any of the scalar*/newArray with `foo is dsa.NoneArray` to
# handle blocks with the array missing, if any.
else:
output.CellData.append(cd_newArray, 'newVal')
