OSPRay: dots in the images
I have just discovered the newly introduced possibility in PV to use OSPRay for more realistic appearance. It looks really nice. Nevertheless, I have several white and red dots on my models, in particular in the window:
I see the same also on that example: https://blog.kitware.com/kitware-talks-sc17-and-releases-for-vtk-paraview-and-cmake/
Is there any reason for it and could it be removed? I’m using PV 5.6.0 under windows.
Many thanks
Martin
This is the noise introduced by the renderer.
In order to remove this, increase the number of samples with the parameter Samples Per Pixel.
Be careful, it will increase the rendering time and freeze the UI until the rendering is complete.
In order to keep the UI interactive and see the image improving, launch ParaView with the option --enable-streaming.
Many thanks. That is the solution.
Michael,
I’ve noticed these spots show up on saved screenshots and is particularly annoying when the background (either of ParaView or in PowerPoint when using transparent background) appears throughout my rendered image. Is there any way to guarantee no spots? Maybe a “samples per pixel” : total pixels relationship?
There isn’t a way to guarantee no noise that I’m aware of, but stay tuned for further developments aimed at reducing this noise.
