OSPRay support not available
Greetings,
I was trying to do some ray trace rendering, but I am missing the option for ‘Enable Ray Tracing’ in the view settings. Also in the material editor shows “OSPray support not available”. Any ideas?
PV client info is pasted below. Thanks!
Client Information:
Version: 5.10.1
VTK Version: 9.0.20210922
Qt Version: 5.15.2
vtkIdType size: 64bits
Embedded Python: On
Python Library Path: /Applications/ParaView-5.10.1.app/Contents/Libraries/lib/python3.9
Python Library Version: 3.9.5 (default, Mar 14 2022, 15:11:26) [Clang 12.0.0 (clang-1200.0.32.29)]
Python Numpy Support: On
Python Numpy Path: /Applications/ParaView-5.10.1.app/Contents/Python/numpy
Python Numpy Version: 1.21.1
Python Matplotlib Support: On
Python Matplotlib Path: /Applications/ParaView-5.10.1.app/Contents/Python/matplotlib
Python Testing: Off
MPI Enabled: On
ParaView Build ID: superbuild 6dd132601dbb2a9ebdc0d31825989f5b92595b76 (!969)
Disable Registry: Off
Test Directory:
Data Directory:
SMP Backend: Sequential
SMP Max Number of Threads: 1
OpenGL Vendor: Apple
OpenGL Version: 4.1 Metal - 83.1
OpenGL Renderer: Apple M2
Connection Information:
Remote Connection: No
@tgalland @Lucas_Givord
MacOS binary release simply does not support raytracing afaics.
@cory.quammen
thanks!
The macOS binaries provided on www.paraview.org/download do support ray tracing.
@caladoa from where did you obtain the binary?
From there…
Ah, I missed the M2 in the OpenGL Renderer. We do not enable OSPRay on arm64 binaries for macOS.
thanks
Just a note that OSPRay being disabled in ParaView’s mac binaries is a legacy from a few years back when the “new” arm Macs came out and OSPRay had not yet been ported to run on them. Current OSPRay does support arm, so it could be made to work by someone adventurous enough to try it.
Is there any update to this as of 2025? Ray tracing seems not to be available with version 5.13.1 on Apple M3.
Hi @aleksandrShukman, that’s interesting. I have tested ParaView 5.13.1 downloaded from www.paraview.org on both M1 and M4 macs and OSPRay ray tracing is available and works.
I just tested my M1 Macbook with 6.0.0-RC1. Ray tracing is available and works. I will say it’s subtle - ray tracing and non ray tracing looks the same. I changed the ambient intensity, and then I saw a change. I also tried shadows, that also works.
