Paravies crashes when running a state
Hello everyone,
I’ve only recently started working with ParaView and am using it for my thesis. Since I’m comparing multiple simulations, I wanted to create a state and import and analyze the different cases. Unfortunately, ParaView crashes immediately after loading. I’m using Fedora Linux and ParaView version 5.13.3, and I’ve also tested it with 5.12.1. I received the following error message on Linux.
christian@fedora:~$ flatpak run --verbose org.paraview.ParaView
F: No installations directory in /etc/flatpak/installations.d. Skipping
F: Opening system flatpak installation at path /var/lib/flatpak
F: Opening user flatpak installation at path /home/christian/.local/share/flatpak
F: Regenerating ld.so.cache /home/christian/.var/app/org.paraview.ParaView/.ld.so/e874996ce39f4dc6bf488277d0f37341b9638a82593ee97aeec8804011b4221a
F: /var/lib/flatpak/runtime/org.kde.Sdk/x86_64/5.15-24.08/144247cfdd84c8f8ddc1db4b287a56a240f6297da0bad54b74a2509c1d05823e/files/lib32 does not exist
F: Running: '/usr/bin/bwrap --args 28 ldconfig -X -C /run/ld-so-cache-dir/e874996ce39f4dc6bf488277d0f37341b9638a82593ee97aeec8804011b4221a.KXgipK'
F: Allocated instance id 86974409
F: Add defaults in dir /org/paraview/ParaView/
F: Add locks in dir /org/paraview/ParaView/
F: Allowing dri access
F: Allowing homedir access
F: Allowing x11 access
F: Running '/usr/bin/bwrap --args 44 -- /usr/bin/xdg-dbus-proxy --args=46'
F: Running '/usr/bin/bwrap --args 44 -- paraview'
Gtk-Message: 12:10:50.309: Failed to load module "canberra-gtk-module"
Gtk-Message: 12:10:50.309: Failed to load module "pk-gtk-module"
Gtk-Message: 12:10:50.310: Failed to load module "canberra-gtk-module"
Gtk-Message: 12:10:50.310: Failed to load module "pk-gtk-module"
qt.qpa.qgnomeplatform: Could not find color scheme  ""
Qt: Session management error: Could not open network socket
/usr/include/c++/14.2.0/bits/stl_vector.h:1149: std::vector<_Tp, _Alloc>::const_reference std::vector<_Tp, _Alloc>::operator[](size_type) const [with _Tp = double; _Alloc = std::allocator<double>; const_reference = const double&; size_type = long unsigned int]: Assertion '__n < this->size()' failed.
[fedora:00002] *** Process received signal ***
[fedora:00002] Signal: Abgebrochen (6)
[fedora:00002] Signal code:  (-6)
[fedora:00002] [ 0] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x41140) [0x7fd5a0c42140]
[fedora:00002] [ 1] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x99db4) [0x7fd5a0c9adb4]
[fedora:00002] [ 2] /usr/lib/x86_64-linux-gnu/libc.so.6(gsignal+0x1e) [0x7fd5a0c4208e]
[fedora:00002] [ 3] /usr/lib/x86_64-linux-gnu/libc.so.6(abort+0xdf) [0x7fd5a0c29882]
[fedora:00002] [ 4] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(+0xe8c1d) [0x7fd5a0ee8c1d]
[fedora:00002] [ 5] /app/bin/../lib/libpqComponents-pv5.13.so.1(_ZN21pqAnimationTimeWidget11pqInternals6renderEPS_+0x773) [0x7fd5b2f5e7d3]
[fedora:00002] [ 6] /usr/lib/x86_64-linux-gnu/libQt5Core.so.5(+0x328a32) [0x7fd5a4928a32]
[fedora:00002] [ 7] /app/bin/../lib/libpqCore-pv5.13.so.1(_ZN16pqAnimationScene13animationTimeEd+0x45) [0x7fd5b2aaa485]
[fedora:00002] [ 8] /usr/lib/x86_64-linux-gnu/libQt5Core.so.5(+0x328a32) [0x7fd5a4928a32]
[fedora:00002] [ 9] /app/bin/../lib/libvtkGUISupportQt-pv5.13.so.1(+0x2ebd5) [0x7fd5b3336bd5]
[fedora:00002] [10] /app/bin/../lib/libvtkCommonCore-pv5.13.so.1(_ZN18vtkCallbackCommand7ExecuteEP9vtkObjectmPv+0x25) [0x7fd5a2ccbf75]
[fedora:00002] [11] /app/bin/../lib/libvtkCommonCore-pv5.13.so.1(+0x1bf9c05) [0x7fd5a2df9c05]
[fedora:00002] [12] /app/bin/../lib/libvtkRemotingServerManager-pv5.13.so.1(+0x180b58) [0x7fd5b1780b58]
[fedora:00002] [13] /app/bin/../lib/libvtkRemotingServerManager-pv5.13.so.1(_ZN25vtkSMDoubleVectorProperty9LoadStateEP15vtkPVXMLElementP17vtkSMProxyLocator+0x4f) [0x7fd5b177f88f]
[fedora:00002] [14] /app/bin/../lib/libvtkRemotingServerManager-pv5.13.so.1(_ZN10vtkSMProxy12LoadXMLStateEP15vtkPVXMLElementP17vtkSMProxyLocator+0x152) [0x7fd5b1803c92]
[fedora:00002] [15] /app/bin/../lib/libvtkRemotingServerManager-pv5.13.so.1(_ZN20vtkSMDeserializerXML8NewProxyEjP17vtkSMProxyLocator+0x125) [0x7fd5b176f645]
[fedora:00002] [16] /app/bin/../lib/libvtkRemotingServerManager-pv5.13.so.1(_ZN17vtkSMProxyLocator11LocateProxyEj+0x1f5) [0x7fd5b1815805]
[fedora:00002] [17] /app/bin/../lib/libvtkRemotingServerManager-pv5.13.so.1(_ZN16vtkSMStateLoader21HandleProxyCollectionEP15vtkPVXMLElement+0xf5) [0x7fd5b1874075]
[fedora:00002] [18] /app/bin/../lib/libvtkRemotingServerManager-pv5.13.so.1(_ZN16vtkSMStateLoader17LoadStateInternalEP15vtkPVXMLElement+0x5b4) [0x7fd5b1875874]
[fedora:00002] [19] /app/bin/../lib/libvtkRemotingServerManager-pv5.13.so.1(_ZN16vtkSMStateLoader9LoadStateEP15vtkPVXMLElementb+0x6f) [0x7fd5b1874d3f]
[fedora:00002] [20] /app/bin/../lib/libvtkRemotingServerManager-pv5.13.so.1(_ZN24vtkSMSessionProxyManager12LoadXMLStateEP15vtkPVXMLElementP16vtkSMStateLoaderb+0x7d) [0x7fd5b184983d]
[fedora:00002] [21] /app/bin/../lib/libvtkRemotingServerManager-pv5.13.so.1(_ZN26vtkSMLoadStateOptionsProxy4LoadEv+0x437) [0x7fd5b17a7927]
[fedora:00002] [22] /app/bin/../lib/libpqApplicationComponents-pv5.13.so.1(_ZN19pqLoadStateReaction9loadStateERK7QStringbP8pqServerj+0x410) [0x7fd5b36021a0]
[fedora:00002] [23] /app/bin/../lib/libpqApplicationComponents-pv5.13.so.1(_ZN19pqLoadStateReaction9loadStateEv+0x6af) [0x7fd5b3602caf]
[fedora:00002] [24] /usr/lib/x86_64-linux-gnu/libQt5Core.so.5(+0x328a32) [0x7fd5a4928a32]
[fedora:00002] [25] /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(_ZN7QAction9triggeredEb+0x42) [0x7fd5b2373d82]
[fedora:00002] [26] /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(_ZN7QAction8activateENS_11ActionEventE+0xb0) [0x7fd5b23769e0]
[fedora:00002] [27] /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x300e02) [0x7fd5b2500e02]
[fedora:00002] [28] /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x308d3b) [0x7fd5b2508d3b]
[fedora:00002] [29] /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5(_ZN7QWidget5eventEP6QEvent+0x298) [0x7fd5b23bd028]
[fedora:00002] *** End of error message ***
I don’t know if I’m doing something wrong here or if it’s a PV issue. I’ve found similar posts but with different error messages.
I’m using a Lenovo laptop with an Intel i9 and an RTX 4070 mobile.
Please share data and state file
I’ve made a WeTransfer Link. The File Size was to big for an Upload on this site.
I’m afraid the provided archive does not seem to extract properly.
