Paraview 5.10.1 doesn't load XML .vtp file correctly
Paraview 5.10.1 doesn’t load XML-format .vtp file correctly
The contents of my XML-format .vtp file are below. Paraview 5.10.1 loads this but only adds 1 rectangle to the viewing area, even though there are 2 rectangles defined.
<?xml version="1.0"?>
<VTKFile type="PolyData" version="0.1" byte_order="LittleEndian">
<PolyData>
<Piece NumberOfPoints="8" NumberOfVerts="0" NumberOfLines="0" NumberOfStrips="0" NumberOfPolys="2">
<Points>
<DataArray type="Float32" Name="points" NumberOfComponents="3" format="ascii">
0.0 0.0 0.0
1.0 0.0 0.0
1.0 0.0 1.0
0.0 0.0 1.0
1.0 0.0 0.0
2.0 0.0 0.0
2.0 0.0 1.0
1.0 0.0 1.0
</DataArray>
</Points>
<CellData scalars="VAR1">
<DataArray type="Float32" Name="VAR1" NumberOfComponents="1" format="ascii">
0.0068
0.0346
</DataArray>
</CellData>
<Polys>
<DataArray type="Int32" Name="connectivity" format="ascii">
0 1 2 3 4 5 6 7
</DataArray>
<DataArray type="Int32" Name="offsets" format="ascii">
0 4
</DataArray>
</Polys>
</Piece>
</PolyData>
</VTKFile>
Fixed the formating.
Your offsets array is incorrect, it should contain 4 8
Thanks, that did the trick.
