Hello
I am trying to build ParaView without X on Oracle Linux 9. I am using python 3.12.2, that I also build myself (with -fPIC). The build goes through just fine. Here my build parameters:
cmake -GNinja -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_SMP_IMPLEMENTATION_TYPE=TBB -DCMAKE_BUILD_TYPE=Release -DPARAVIEW_USE_QT=OFF -DVTK_USE_X=OFF -DVTK_OPENGL_HAS_EGL=ON -DVTK_PYTHON_OPTIONAL_LINK=OFF ../paraview
Now when I am trying to run pypython I get the following error:
*** Process received signal ***
Signal: Segmentation fault (11)
Signal code: Address not mapped (1)
Failing at address: 0x10
[ 0] /lib64/libc.so.6(+0x54db0)[0x7feeb06eedb0]
[ 1] /mnt/software/paraview/5.12.0_py-3.12.2/bin/../lib64/libvtkPythonInterpreter-pv5.12.so.1(+0xe8507)[0x7feeae615507]
[ 2] /mnt/software/paraview/5.12.0_py-3.12.2/bin/../lib64/libvtkPythonInterpreter-pv5.12.so.1(Py_RunMain+0x16)[0x7feeae616236]
[ 3] /mnt/software/paraview/5.12.0_py-3.12.2/bin/../lib64/libvtkPythonInterpreter-pv5.12.so.1(_ZN20vtkPythonInterpreter6PyMainEiPPc+0x2bc)[0x7feeae613dfc]
[ 4] bin/pvpython[0x430a44]
[ 5] /lib64/libc.so.6(+0x3feb0)[0x7feeb06d9eb0]
[ 6] /lib64/libc.so.6(__libc_start_main+0x80)[0x7feeb06d9f60]
[ 7] bin/pvpython[0x4304f5]
*** End of error message ***
Segmentation fault (core dumped)
I could not figure out what the issue was, so I downgraded python to 3.11.8 and otherwise left everything the same and the software works without problem. Do you have any idea where this is coming from? Is this an issue with ParaView and the newest python version?
Any help is very welcome!
Jasmin
