Paraview 5.12: Cannot modify the Camera spline path interactively (using the mouse)
In Paraview 5.12 RC2 when I use the Time Manager (View > Time Manager) then I add the Camera to follow a Path, I cannot modify the path of the camera (the spline) interactively (using the mouse). I remember being able to do that in previous versions.
Here is a screenshot:
In the screenshot, the white line is the camera path (it is a circular path), I cannot click on it because the top dialog is activated. When I press on the “OK” button, the path disappears.
Thank you
Indeed, looks like there is a model window that prevent the eddition.
Wdyt @nicolas.vuaille ?
It is indeed a regression, an issue was opened (https://gitlab.kitware.com/paraview/paraview/-/issues/22416).
Actually, this was a really small fix, so I did it here: https://gitlab.kitware.com/paraview/paraview/-/merge_requests/6665
Many thanks for the fix.
@nicolas.vuaille Will this fix be available in Paraview 5.12? or 5.13?. I personally wish it will be released in 5.12.
Regards
It will be part of 5.12!
