Before I attempt to build paraview on MacOS from source, is there any reason why the MacOS build from the download link does not include paraview.simple.Conduit?
I am attempting to connect a paraview client on MacOS with a remote catalyst v2 session and it appears to be failing because paraview.simple.Conduit is missing.
I’m not sure I understand your question. paraview.simple is a package of mostly functions that ease Python scripting in ParaView, and there is not a Conduit package in it AFAIK.
Are you seeing an error message that you could report?
This is the error I get from the MacOS client when the catalyst session connects.
ERROR: In vtkSIProxyDefinitionManager.cxx, line 518
vtkSIProxyDefinitionManager (0x6000022cd980): No proxy that matches: group=sources and proxy=Conduit were found.
ERROR: In vtkSMDeserializerXML.cxx, line 42
vtkSMStateLoader (0x600002793870): Could not create a proxy of group: sources type: Conduit
The Linux client seems to have paraview.simple.Conduit installed but I have not been able to test with the Linux client to see if I get the same error.
My MacOS client is connected to a pvserver session before I start the catalyst connection, if that helps.
I think you are correct. From the python shell I get
File “”, line 1, in
ModuleNotFoundError: No module named ‘vtkmodules.vtkIOCatalystConduit’
Also looking at the paraview-superbuild ci settings it looks like the catalyst project is only enabled on the Linux build so I assume the default MacOS build does not include it.
I will attempt to turn on the catalyst project for my MacOS build and let you know if it works.
