Hi.
I’m working only with MED files and I don’t know if this applies to any other format. If I want to reload a file, using reload function, I’m loosing possibility to see results in vewport. All data is present in pipeline browser, but I can’t see anything in 3D. The only way I found to deal with the problem is deleting all the work from pipeline and manually reopen the file.
The same thing happened in v5.12
Hi @K_Zurawski
This sounds like a bug in the MEDReaderPlugin, however this plugin is maintained by the salome/paravis team, you may want to reach out to them.
Thanks, I’ll do that.
Just wanted to add error message in case this is not MEDReaderPlugin error:
Exception has been thrown in vtkMEDReader::RequestInformation : File : "" has been detected as NOT EXISTING : impossible to read anything !
ERROR: In vtkExecutive.cxx, line 730
vtkPVCompositeDataPipeline (0000019A5D6AF100): Algorithm vtkFileSeriesGroupReader (0000019A5238E7E0) returned failure for request: vtkInformation (0000019A5DF61420)
Debug: Off
Modified Time: 1554584
Reference Count: 1
Registered Events: (none)
Request: REQUEST_INFORMATION
FORWARD_DIRECTION: 0
ALGORITHM_AFTER_FORWARD: 1
vtkPVCompositeDataPipeline (0000019A5D6AF340): Algorithm vtkMEDReader (0000019A5D6AEA40) returned failure for request: vtkInformation (0000019A5DF5C4F0)
Debug: Off
Modified Time: 1554615
Reference Count: 1
debug: In unknown, line 0
debug: Found an unknow Field in pqAbstractFieldsWidget::setFields, ignoring
vtkPVCompositeDataPipeline (0000019A5DE68DE0): Algorithm vtkFileSeriesGroupReader (0000019A51F20490) returned failure for request: vtkInformation (0000019A5DE417F0)
Debug: Off
Modified Time: 1949196
Reference Count: 1
vtkPVCompositeDataPipeline (0000019A5DE6AC40): Algorithm vtkMEDReader (0000019A5DE69260) returned failure for request: vtkInformation (0000019A5DE4DDB0)
Debug: Off
Modified Time: 1949227
Reference Count: 1
This means it is coming from the MEDReader plugin.
Thank you.
