I am using ParaView-5.6.0-MPI-Linux-64bit that I downloaded from paraview.org. I have a binary file of 16 x 16 x 16 floats in little endian that I try to load in ParaView using “Image Reader”. I then use:
Data Scalar Type: float
Data Byte Order: LittleEndian
Data Origin 0 0 0
Data Spacing 1 1 1
Number Of Scalar Components: 1
File Lower Left: true
Scalar Array Name: density
File DImensionality: 3
Data Extent:
0 0
0 0
0 0
I then get the following crash message in the terminal:
Generic Warning: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_superbuild/build/
superbuild/paraview/src/VTK/Parallel/MPI/vtkMPICommunicator.cxx, line 71
MPI had an error
Invalid argument, error stack:
MPI_Type_create_subarray(344): MPI_Type_create_subarray(ndims=3, array_of_sizes=0x7fff1d1aeca0, array_of_subsizes=0
x7fff1d1aecb0, array_of_starts=0x7fff1d1aecc0, order=57, MPI_BYTE, newtype=0x7fff1d1aec98) failed
MPI_Type_create_subarray(127): Argument array_of_starts has value 4 but must be within [0,0]
application called MPI_Abort(MPI_COMM_WORLD, 873079820) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=873079820
system msg for write_line failure : Bad file descriptor
I have included the raw binary file: simpleData.raw (16 KB)
For comparison, I also wrote an XDMF file that describes the binary data. This works fine. simpleData.xmf (778 Bytes)
Does this crash for other people as well? If so, I’ll create a bug report.
Or am I simply doing something wrong?
Hi Jarno,
It appears to me that you are not even getting as far as your data. Looks like you played around in the Settings file? Did you enable Auto MPI? If so, I would recommend turning it off. Generally, first thing to do if things break is go back to default. If you DIDN’T turn on MPI, then there is a different - and stranger - issue.
Hi, I reset my settings by deleting ~/.config/ParaView and did the same things as before.
jarno@workjarno:~/.config$ mv ParaView/ ParaView.bak
jarno@workjarno:~/.config$ paraview
Generic Warning: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_superbuild/build/superbuild/paraview/src/VTK/Parallel/MPI/vtkMPICommunicator.cxx, line 71
MPI had an error
MPI_Type_create_subarray(344): MPI_Type_create_subarray(ndims=3, array_of_sizes=0x7ffe67da0160, array_of_subsizes=0x7ffe67da0170, array_of_starts=0x7ffe67da0180, order=57, MPI_BYTE, newtype=0x7ffe67da0158) failed
application called MPI_Abort(MPI_COMM_WORLD, 269100044) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=269100044
I noticed I wrote some of the Image Reader setting wrong in my post. Data extent should be from 1 to 16, not 0 to 0 of course, but it looks like you spotted that already.
Here’s my settings file, though it doesn’t contain much. ParaView5.6.0.ini (1004 Bytes)
I still double-checked the Settings screen and “Enable Auto MPI” is off.
This is on a stock install of Kubuntu 18.04 by the way.
With your setup of the reading of the .raw file, I have the following error. It is different to your error though :
ERROR: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_superbuild/build/superbuild/paraview/src/ParaViewCore/ClientServerCore/Rendering/vtkPVImageSliceMapper.cxx, line 241
vtkPVImageSliceMapper (0xa319900): Incorrect dimensionality.
