Rojj
(Ruggiero Guida)
1
I have noticed a different behaviour between Paraview 5.6 and 4.4.
radiation_surface_total_shortwave_ssaw-maen-smtwtfs_avg.vtk (36.0 KB)
Have a look at the attached file.
In Paraview 4.4, when I select Miscellaneous -> Triangulate I get this
In Paraview 5.6 I get this
Is there any setting that I am missing?
Thanks
mwestphal
(Mathieu Westphal (Kitware))
2
Your datasets contains duplicated points and the data is located on the cells.
The Triangulate seems to have been improved since ParaView 4.4.
In order to get what you are looking for you need to remove the duplicated points and then interpolate the data on the points.
Here is how to do it :
- Open your dataset with ParaView
- Add a “Clean To Grid” filter, Apply
- Add a “CellData to PointData” filter, Apply
