Hello!
Paraview opens with some fontconfig erros if not using Bumblebee but it wont open at all using optirun. Will the Nvidia Index plugin work without using bumblebee?
I have the Paraview-MPI-Linux 5.6 (not mesa) installed on a OpenSuse Tumbleweed.
optirun --debug ./paraview
[24541.630075] [DEBUG]optirun version 3.2.1 starting…
[24541.630126] [DEBUG]Active configuration:
[24541.630134] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[24541.630143] [DEBUG] X display: :8
[24541.630150] [DEBUG] LD_LIBRARY_PATH: /usr/lib64/nvidia:/usr/lib/nvidia
[24541.630164] [DEBUG] Socket path: /var/run/bumblebee.socket
[24541.630180] [DEBUG] Accel/display bridge: auto
[24541.630190] [DEBUG] VGL Compression: proxy
**[24541.630202] [DEBUG] VGLrun extra options: **
[24541.630210] [DEBUG] Primus LD Path: /usr/lib64/primus:/usr/lib/primus
[24541.630390] [DEBUG]Using auto-detected bridge virtualgl
[24542.683628] [INFO]Response: Yes. X is active.
[24542.683641] [INFO]Running application using virtualgl.
[24542.683764] [DEBUG]Process vglrun started, PID 1889.
Fontconfig warning: “/etc/fonts/fonts.conf”, line 5: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/fonts.conf”, line 6: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/fonts.conf”, line 6: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/fonts.conf”, line 6: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/fonts.conf”, line 7: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/fonts.conf”, line 7: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/fonts.conf”, line 9: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/10-hinting-slight.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/10-hinting-slight.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/10-hinting-slight.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/10-hinting-slight.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/10-hinting-slight.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/10-hinting-slight.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/10-hinting-slight.conf”, line 8: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/10-scale-bitmap-fonts.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/10-scale-bitmap-fonts.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/10-scale-bitmap-fonts.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/10-scale-bitmap-fonts.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/10-scale-bitmap-fonts.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/10-scale-bitmap-fonts.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/10-scale-bitmap-fonts.conf”, line 8: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/20-unhint-small-vera.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/20-unhint-small-vera.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/20-unhint-small-vera.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/20-unhint-small-vera.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/20-unhint-small-vera.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/20-unhint-small-vera.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/20-unhint-small-vera.conf”, line 8: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/30-metric-aliases.conf”, line 8: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/30-metric-aliases.conf”, line 9: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/30-metric-aliases.conf”, line 9: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/30-metric-aliases.conf”, line 9: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/30-metric-aliases.conf”, line 10: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/30-metric-aliases.conf”, line 10: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/30-metric-aliases.conf”, line 12: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/40-nonlatin.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/40-nonlatin.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/40-nonlatin.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/40-nonlatin.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/40-nonlatin.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/40-nonlatin.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/40-nonlatin.conf”, line 8: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/45-generic.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/45-generic.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/45-generic.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/45-generic.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/45-generic.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/45-generic.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/45-generic.conf”, line 8: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/45-latin.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/45-latin.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/45-latin.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/45-latin.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/45-latin.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/45-latin.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/45-latin.conf”, line 8: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/49-sansserif.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/49-sansserif.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/49-sansserif.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/49-sansserif.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/49-sansserif.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/49-sansserif.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/49-sansserif.conf”, line 8: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/56-user.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/56-user.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/56-user.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/56-user.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/56-user.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/56-user.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/56-user.conf”, line 8: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/60-generic.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/60-generic.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/60-generic.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/60-generic.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/60-generic.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/60-generic.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/60-generic.conf”, line 8: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/61-latin.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/61-latin.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/61-latin.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/61-latin.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/61-latin.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/61-latin.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/61-latin.conf”, line 8: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/65-fonts-persian.conf”, line 34: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/65-fonts-persian.conf”, line 35: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/65-fonts-persian.conf”, line 35: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/65-fonts-persian.conf”, line 35: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/65-fonts-persian.conf”, line 36: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/65-fonts-persian.conf”, line 36: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/65-nonlatin.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/65-nonlatin.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/65-nonlatin.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/65-nonlatin.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/65-nonlatin.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/65-nonlatin.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/65-nonlatin.conf”, line 8: unknown element "description"
Fontconfig warning: “/etc/fonts/conf.d/69-unifont.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/69-unifont.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/69-unifont.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/69-unifont.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/69-unifont.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/69-unifont.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/80-delicious.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/80-delicious.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/80-delicious.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/80-delicious.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/80-delicious.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/80-delicious.conf”, line 6: invalid attribute 'version’
Fontconfig warning: “/etc/fonts/conf.d/90-synthetic.conf”, line 4: unknown element "its:rules"
Fontconfig warning: “/etc/fonts/conf.d/90-synthetic.conf”, line 5: unknown element "its:translateRule"
Fontconfig error: “/etc/fonts/conf.d/90-synthetic.conf”, line 5: invalid attribute 'translate’
Fontconfig error: “/etc/fonts/conf.d/90-synthetic.conf”, line 5: invalid attribute 'selector’
Fontconfig error: “/etc/fonts/conf.d/90-synthetic.conf”, line 6: invalid attribute 'xmlns:its’
Fontconfig error: “/etc/fonts/conf.d/90-synthetic.conf”, line 6: invalid attribute 'version’
Fontconfig error: Cannot load config file from /etc/fonts/fonts.conf
[24543.798241] [DEBUG]SIGCHILD received, but wait failed with No child processes
[24543.798261] [DEBUG]Socket closed.
[24543.798278] [DEBUG]Killing all remaining processes.
