Paraview 5.7 crash on connection configuration menu
I’m experiencing a GUI crash when trying to open the command connection configuration window. I reproduce it and save it as a gif.
this is the log:
praview_5.7_crash_log.txt (4.9 KB)
Can you reproduce it on your side?
I built it using paraview superbuild and linked it with my system’s qt 5.10.1 installation.
Thanks
reported here : https://gitlab.kitware.com/paraview/paraview/-/issues/19445
As a work around, you can define your server command in the .pvsc file in your settings.
In the case a fix is release it soon, can it be as a patch for 5.7? or Do I have to go up to 5.8 or whatever is in the master branch ?
If fixed, it will only be available in ParaView 5.8.1 or ParaView 5.9.
