To make it crash, load the state file (with the data bs…pvtu) then try to display the point probe time history.
I think this may have something to do with the fact that some of the numbers in the data files are small i.e. 1.0e-35 (which is my own issue), but this shouldn’t cause Paraview to crash in any case.
Well. At least it is reproducible. I read another thread where numbers with a small negative exponent were causing crashes. I replaced everything with an exponent more negative than e-16 and the crash went away. Before I did that I was getting an error:
ERROR: In /Users/kitware/dashboards/buildbot-slave/a64f5607/build/superbuild/paraview/src/VTK/IO/XML/vtkXMLUnstructuredDataReader.cxx, line 527
vtkXMLUnstructuredGridReader (0x7ff50e906980): Cannot read points array from Points in piece 0. The data array in the element may be too short.
