After using the styling attributes “Line width” and “Render Lines as Tubes”, disabling Light kit will make paraview to crash… I have tried the same in Paraview Versions 5.5.0 and 5.6.0 and It works fine, but for paraview 5.8.x it crashes with the following error:
( 88.577s) [paraview ] vtkShaderProgram.cxx:468 ERR| vtkShaderProgram (0x61f4670): 1: #version 150
2: #ifdef GL_ES
3: #ifdef GL_FRAGMENT_PRECISION_HIGH
4: precision highp float;
5: #else
6: precision mediump float;
7: #endif
8: #else // GL_ES
9: #define highp
10: #define mediump
11: #define lowp
12: #endif // GL_ES
13:
14:
15: /*=========================================================================
16:
17: Program: Visualization Toolkit
18: Module: vtkPolyDataWideLineGS.glsl
19:
20: Copyright (c) Ken Martin, Will Schroeder, Bill Lorensen
21: All rights reserved.
22: See Copyright.txt or http://www.kitware.com/Copyright.htm for details.
23:
24: This software is distributed WITHOUT ANY WARRANTY; without even
25: the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
26: PURPOSE. See the above copyright notice for more information.
27:
28: =========================================================================*/
29: // Template for the polydata mappers geometry shader
30:
31: // VC position of this fragment
32: //VTK::PositionVC::Dec
33:
34: // primitiveID
35: //VTK::PrimID::Dec
36:
37: // optional color passed in from the vertex shader, vertexColor
38: //VTK::Color::Dec
39:
40: // optional surface normal declaration
41: out vec3 tubeBasis1;
42: out vec3 tubeBasis2;
43:
44:
45: // extra lighting parameters
46: //VTK::Light::Dec
47:
48: // Texture coordinates
49: //VTK::TCoord::Dec
50:
51: // picking support
52: //VTK::Picking::Dec
53:
54: // Depth Peeling Support
55: //VTK::DepthPeeling::Dec
56:
57: // clipping plane vars
58: //VTK::Clip::Dec
59:
60: // the output of this shader
61: //VTK::Output::Dec
62:
63: uniform vec2 lineWidthNVC;
64:
65: layout(lines) in;
66: layout(triangle_strip, max_vertices = 4) out;
67:
68: void main()
69: {
70: // compute the lines direction
71: vec2 normal = normalize(
72: gl_in[1].gl_Position.xy/gl_in[1].gl_Position.w -
73: gl_in[0].gl_Position.xy/gl_in[0].gl_Position.w);
74:
75: // rotate 90 degrees
76: normal = vec2(-1.0*normal.y,normal.x);
77:
78: vec3 lineDir = normalize(vertexVCVSOutput[1].xyz - vertexVCVSOutput[0].xyz);
79: tubeBasis2 = normalize(cross(lineDir, vec3(normal, 0.0)));
80: tubeBasis2 = tubeBasis2*sign(tubeBasis2.z);
81:
82:
83: for (int j = 0; j < 4; j++)
84: {
85: int i = j/2;
86:
87: gl_PrimitiveID = gl_PrimitiveIDIn;
88:
89: //VTK::Clip::Impl
90:
91: //VTK::Color::Impl
92:
93: tubeBasis1 = 2.0*vec3(normal*((j+1)%2 - 0.5), 0.0);
94:
95:
96: //VTK::Light::Impl
97:
98: //VTK::TCoord::Impl
99:
100: //VTK::DepthPeeling::Impl
101:
102: //VTK::Picking::Impl
103:
104: // VC position of this fragment
105: //VTK::PositionVC::Impl
106:
107: gl_Position = vec4(
108: gl_in[i].gl_Position.xy + (lineWidthNVC*normal)*((j+1)%2 - 0.5)*gl_in[i].gl_Position.w,
109: gl_in[i].gl_Position.z,
110: gl_in[i].gl_Position.w);
111: EmitVertex();
112: }
113: EndPrimitive();
114: }
( 88.581s) [paraview ] vtkShaderProgram.cxx:469 ERR| vtkShaderProgram (0x61f4670): 0(78) : error C1503: undefined variable "vertexVCVSOutput"
Steps to reproduce:
- open paraview gui
- go to Sources -> Alphabetical -> Line -> Apply
- In Styling properties:
- select Render Lines as Tubes
- change Line width to 1.5
- go to View - > Light Inspector
- disable Light kit
It was indeed a little bug and I fixed it here :
