Hello again,
So I’ve been double checking the script, and regarding the problem with changing Arrow to Sphere in glyphs I messed it up in vim editor so that is ok now.
But how do I change the number of streamlines within the sphere (the number of points seed points is 100 here)?
# trace generated using paraview version 5.9.1
#### import the simple module from the paraview
from paraview.simple import *
#### disable automatic camera reset on 'Show'
# create a new 'NetCDF Reader'
interpolatednc = NetCDFReader(registrationName='interpolated.nc', FileName=['/home/interpolation/interpolated.nc'])
interpolatednc.Dimensions = '(z, y, x)'
# get animation scene
animationScene1 = GetAnimationScene()
# update animation scene based on data timesteps
animationScene1.UpdateAnimationUsingDataTimeSteps()
# Properties modified on interpolatednc
interpolatednc.SphericalCoordinates = 0
interpolatednc.OutputType = 'Image'
# get active view
# show data in view
interpolatedncDisplay = Show(interpolatednc, renderView1, 'UniformGridRepresentation')
# trace defaults for the display properties.
interpolatedncDisplay.Representation = 'Outline'
interpolatedncDisplay.ColorArrayName = [None, '']
interpolatedncDisplay.SelectTCoordArray = 'None'
interpolatedncDisplay.SelectNormalArray = 'None'
interpolatedncDisplay.SelectTangentArray = 'None'
interpolatedncDisplay.OSPRayScaleArray = 'terrain'
interpolatedncDisplay.OSPRayScaleFunction = 'PiecewiseFunction'
interpolatedncDisplay.SelectOrientationVectors = 'None'
interpolatedncDisplay.ScaleFactor = 143.6
interpolatedncDisplay.SelectScaleArray = 'None'
interpolatedncDisplay.GlyphType = 'Arrow'
interpolatedncDisplay.GlyphTableIndexArray = 'None'
interpolatedncDisplay.GaussianRadius = 7.18
interpolatedncDisplay.SetScaleArray = ['POINTS', 'terrain']
interpolatedncDisplay.ScaleTransferFunction = 'PiecewiseFunction'
interpolatedncDisplay.OpacityArray = ['POINTS', 'terrain']
interpolatedncDisplay.OpacityTransferFunction = 'PiecewiseFunction'
interpolatedncDisplay.DataAxesGrid = 'GridAxesRepresentation'
interpolatedncDisplay.PolarAxes = 'PolarAxesRepresentation'
interpolatedncDisplay.ScalarOpacityUnitDistance = 5.170266879832471
interpolatedncDisplay.OpacityArrayName = ['POINTS', 'terrain']
interpolatedncDisplay.SliceFunction = 'Plane'
interpolatedncDisplay.Slice = 60
#interpolatedncDisplay.InputVectors = [None, '']
# init the 'Plane' selected for 'SliceFunction'
interpolatedncDisplay.SliceFunction.Origin = [719.0, 719.0, 119.5]
# reset view to fit data
renderView1.ResetCamera()
# get the material library
materialLibrary1 = GetMaterialLibrary()
# update the view to ensure updated data information
renderView1.Update()
# set scalar coloring
ColorBy(interpolatedncDisplay, ('POINTS', 'terrain'))
# rescale color and/or opacity maps used to include current data range
interpolatedncDisplay.RescaleTransferFunctionToDataRange(True, False)
# show color bar/color legend
interpolatedncDisplay.SetScalarBarVisibility(renderView1, True)
# get color transfer function/color map for 'terrain'
terrainLUT = GetColorTransferFunction('terrain')
# get opacity transfer function/opacity map for 'terrain'
terrainPWF = GetOpacityTransferFunction('terrain')
# change representation type
interpolatedncDisplay.SetRepresentationType('Volume')
# invert the transfer function
terrainLUT.InvertTransferFunction()
# Apply a preset using its name. Note this may not work as expected when presets have duplicate names.
terrainLUT.ApplyPreset('X Ray', True)
v_5nc = NetCDFReader(registrationName='v_5.nc', FileName=['/home/interpolation/v_5.nc'])
v_5nc.Dimensions = '(z, y, x)'
# Properties modified on v_5nc
v_5nc.SphericalCoordinates = 0
v_5nc.OutputType = 'Image'
# show data in view
v_5ncDisplay = Show(v_5nc, renderView1, 'UniformGridRepresentation')
v_5ncDisplay.Representation = 'Outline'
v_5ncDisplay.ColorArrayName = [None, '']
v_5ncDisplay.SelectTCoordArray = 'None'
v_5ncDisplay.SelectNormalArray = 'None'
v_5ncDisplay.SelectTangentArray = 'None'
v_5ncDisplay.OSPRayScaleArray = 'u'
v_5ncDisplay.OSPRayScaleFunction = 'PiecewiseFunction'
v_5ncDisplay.SelectOrientationVectors = 'None'
v_5ncDisplay.ScaleFactor = 143.6
v_5ncDisplay.SelectScaleArray = 'None'
v_5ncDisplay.GlyphType = 'Arrow'
v_5ncDisplay.GlyphTableIndexArray = 'None'
v_5ncDisplay.GaussianRadius = 7.18
v_5ncDisplay.SetScaleArray = ['POINTS', 'u']
v_5ncDisplay.ScaleTransferFunction = 'PiecewiseFunction'
v_5ncDisplay.OpacityArray = ['POINTS', 'u']
v_5ncDisplay.OpacityTransferFunction = 'PiecewiseFunction'
v_5ncDisplay.DataAxesGrid = 'GridAxesRepresentation'
v_5ncDisplay.PolarAxes = 'PolarAxesRepresentation'
v_5ncDisplay.ScalarOpacityUnitDistance = 5.170266879832471
v_5ncDisplay.OpacityArrayName = ['POINTS', 'u']
v_5ncDisplay.SliceFunction = 'Plane'
v_5ncDisplay.Slice = 60
#v_5ncDisplay.InputVectors = [None, '']
# init the 'PiecewiseFunction' selected for 'ScaleTransferFunction'
v_5ncDisplay.ScaleTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 7.755956649780273, 1.0, 0.5, 0.0]
# init the 'PiecewiseFunction' selected for 'OpacityTransferFunction'
v_5ncDisplay.OpacityTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 7.755956649780273, 1.0, 0.5, 0.0]
v_5ncDisplay.SliceFunction.Origin = [719.0, 719.0, 119.5]
# create a new 'Python Calculator'
pythonCalculator1 = PythonCalculator(registrationName='PythonCalculator1', Input=v_5nc)
pythonCalculator1.Expression = ''
# Properties modified on pythonCalculator1
pythonCalculator1.Expression = 'make_vector(u,v,w)'
pythonCalculator1.ArrayName = '3d_velocity'
# show data in view
pythonCalculator1Display = Show(pythonCalculator1, renderView1, 'UniformGridRepresentation')
pythonCalculator1Display.Representation = 'Outline'
pythonCalculator1Display.ColorArrayName = [None, '']
pythonCalculator1Display.SelectTCoordArray = 'None'
pythonCalculator1Display.SelectNormalArray = 'None'
pythonCalculator1Display.SelectTangentArray = 'None'
pythonCalculator1Display.OSPRayScaleArray = '3d_velocity'
pythonCalculator1Display.OSPRayScaleFunction = 'PiecewiseFunction'
pythonCalculator1Display.SelectOrientationVectors = '3d_velocity'
pythonCalculator1Display.ScaleFactor = 143.6
pythonCalculator1Display.SelectScaleArray = '3d_velocity'
pythonCalculator1Display.GlyphType = 'Arrow'
pythonCalculator1Display.GlyphTableIndexArray = '3d_velocity'
pythonCalculator1Display.GaussianRadius = 7.18
pythonCalculator1Display.SetScaleArray = ['POINTS', '3d_velocity']
pythonCalculator1Display.ScaleTransferFunction = 'PiecewiseFunction'
pythonCalculator1Display.OpacityArray = ['POINTS', '3d_velocity']
pythonCalculator1Display.OpacityTransferFunction = 'PiecewiseFunction'
pythonCalculator1Display.DataAxesGrid = 'GridAxesRepresentation'
pythonCalculator1Display.PolarAxes = 'PolarAxesRepresentation'
pythonCalculator1Display.ScalarOpacityUnitDistance = 5.170266879832471
pythonCalculator1Display.OpacityArrayName = ['POINTS', '3d_velocity']
pythonCalculator1Display.SliceFunction = 'Plane'
pythonCalculator1Display.Slice = 60
#pythonCalculator1Display.InputVectors = ['POINTS', '3d_velocity']
pythonCalculator1Display.ScaleTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 7.755956649780273, 1.0, 0.5, 0.0]
pythonCalculator1Display.OpacityTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 7.755956649780273, 1.0, 0.5, 0.0]
pythonCalculator1Display.SliceFunction.Origin = [719.0, 719.0, 119.5]
# hide data in view
Hide(v_5nc, renderView1)
ColorBy(pythonCalculator1Display, ('POINTS', '3d_velocity', 'Magnitude'))
pythonCalculator1Display.RescaleTransferFunctionToDataRange(True, False)
pythonCalculator1Display.SetScalarBarVisibility(renderView1, True)
# get color transfer function/color map for 'a3d_velocity'
a3d_velocityLUT = GetColorTransferFunction('a3d_velocity')
# get opacity transfer function/opacity map for 'a3d_velocity'
a3d_velocityPWF = GetOpacityTransferFunction('a3d_velocity')
pythonCalculator1Display.SetRepresentationType('Volume')
# create a new 'Stream Tracer'
streamTracer1 = StreamTracer(registrationName='StreamTracer1', Input=pythonCalculator1,
SeedType='Line')
streamTracer1.Vectors = ['POINTS', '3d_velocity']
streamTracer1.MaximumStreamlineLength = 1436.0
# init the 'Line' selected for 'SeedType'
streamTracer1.SeedType.Point1 = [1.0, 1.0, 0.0]
streamTracer1.SeedType.Point2 = [1437.0, 1437.0, 239.0]
# toggle 3D widget visibility (only when running from the GUI)
Show3DWidgets(proxy=streamTracer1.SeedType)
# Properties modified on streamTracer1
streamTracer1.SeedType = 'Point Cloud'
# show data in view
streamTracer1Display = Show(streamTracer1, renderView1, 'GeometryRepresentation')
streamTracer1Display.Representation = 'Surface'
streamTracer1Display.ColorArrayName = ['POINTS', '3d_velocity']
streamTracer1Display.LookupTable = a3d_velocityLUT
streamTracer1Display.SelectTCoordArray = 'None'
streamTracer1Display.SelectNormalArray = 'None'
streamTracer1Display.SelectTangentArray = 'None'
streamTracer1Display.OSPRayScaleArray = '3d_velocity'
streamTracer1Display.OSPRayScaleFunction = 'PiecewiseFunction'
streamTracer1Display.SelectOrientationVectors = 'Normals'
streamTracer1Display.ScaleFactor = 143.63591489195824
streamTracer1Display.SelectScaleArray = '3d_velocity'
streamTracer1Display.GlyphType = 'Arrow'
streamTracer1Display.GlyphTableIndexArray = '3d_velocity'
streamTracer1Display.GaussianRadius = 7.181795744597912
streamTracer1Display.SetScaleArray = ['POINTS', '3d_velocity']
streamTracer1Display.ScaleTransferFunction = 'PiecewiseFunction'
streamTracer1Display.OpacityArray = ['POINTS', '3d_velocity']
streamTracer1Display.OpacityTransferFunction = 'PiecewiseFunction'
streamTracer1Display.DataAxesGrid = 'GridAxesRepresentation'
streamTracer1Display.PolarAxes = 'PolarAxesRepresentation'
#streamTracer1Display.InputVectors = ['POINTS', 'Normals']
streamTracer1Display.ScaleTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 6.752197265625, 1.0, 0.5, 0.0]
streamTracer1Display.OpacityTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 6.752197265625, 1.0, 0.5, 0.0]
streamTracer1Display.SetScalarBarVisibility(renderView1, True)
# hide data in view
Hide(pythonCalculator1, renderView1)
# create a new 'Glyph'
glyph1 = Glyph(registrationName='Glyph1', Input=streamTracer1,
GlyphType='Sphere')
glyph1.OrientationArray = ['POINTS', 'Normals']
glyph1.ScaleArray = ['POINTS', '3d_velocity']
glyph1.ScaleFactor = 143.63591489195824
glyph1.GlyphTransform = 'Transform2'
# show data in view
glyph1Display = Show(glyph1, renderView1, 'GeometryRepresentation')
glyph1Display.Representation = 'Surface'
glyph1Display.ColorArrayName = ['POINTS', '3d_velocity']
glyph1Display.LookupTable = a3d_velocityLUT
glyph1Display.SelectTCoordArray = 'None'
glyph1Display.SelectNormalArray = 'None'
glyph1Display.SelectTangentArray = 'None'
glyph1Display.OSPRayScaleArray = '3d_velocity'
glyph1Display.OSPRayScaleFunction = 'PiecewiseFunction'
glyph1Display.SelectOrientationVectors = 'Normals'
glyph1Display.ScaleFactor = 287.66790771484375
glyph1Display.SelectScaleArray = '3d_velocity'
glyph1Display.GlyphType = 'Arrow'
glyph1Display.GlyphTableIndexArray = '3d_velocity'
glyph1Display.GaussianRadius = 14.383395385742189
glyph1Display.SetScaleArray = ['POINTS', '3d_velocity']
glyph1Display.ScaleTransferFunction = 'PiecewiseFunction'
glyph1Display.OpacityArray = ['POINTS', '3d_velocity']
glyph1Display.OpacityTransferFunction = 'PiecewiseFunction'
glyph1Display.DataAxesGrid = 'GridAxesRepresentation'
glyph1Display.PolarAxes = 'PolarAxesRepresentation'
#glyph1Display.InputVectors = ['POINTS', 'Normals']
glyph1Display.ScaleTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 6.115447998046875, 1.0, 0.5, 0.0]
glyph1Display.OpacityTransferFunction.Points = [0.0, 0.0, 0.5, 0.0, 6.115447998046875, 1.0, 0.5, 0.0]
glyph1Display.SetScalarBarVisibility(renderView1, True)
# Properties modified on glyph1
glyph1.OrientationArray = ['POINTS', '3d_velocity']
glyph1.ScaleArray = ['POINTS', 'No scale array']
glyph1.ScaleFactor = 30.163542127311228
glyph1.ScaleFactor = 51.708929361104964
# addendum: following script captures some of the application
# state to faithfully reproduce the visualization during playback
# get layout
layout1 = GetLayout()
# saving layout sizes for layouts
# layout/tab size in pixels
layout1.SetSize(1328, 659)
# saving camera placements for views
# current camera placement for renderView1
renderView1.CameraPosition = [719.0, 719.0, 4069.800312425404]
renderView1.CameraFocalPoint = [719.0, 719.0, 119.5]
renderView1.CameraParallelScale = 1022.4129547301325
RenderAllViews()
Interact()
Thank you.
