Paraview 6.0.1 3D interaction latency/wiggles
First, I would like to thanks Kitware’s developer for providing such great tool.
When trying to upgrade to 6.0.1, I noticed weird latency/wiggles of the meshed actor when interacting with a sphere source, which was not occurring with 5.11. I attached on screenshot video for each version, trying my best to highlight the issue.
Trying with a colleague of mine laptop’s revealed that the issue was due to our graphics card being slightly different, as reported by the Help -> About We have exactly the same fields except:
My laptop His
OpenGL Renderer: NVIDIA GeForce RTX 3050 Ti Laptop GPU/PCIe/SSE2 OpenGL Renderer: NVIDIA GeForce RTX 4050 Ti Laptop GPU/PCIe/SSE2
Here is my full Help -> About report for 6.0.1:
Client Information:
Version: 6.0.1
VTK Version: 9.5.2
Qt Version: 6.9.0
vtkIdType size: 64bits
Embedded Python: On
Python Library Path: C:\Program Files\ParaView 6.0.1\bin\Lib
Python Library Version: 3.12.7 (tags/v3.12.7:0b05ead, Oct  1 2024, 03:06:41) [MSC v.1941 64 bit (AMD64)]
Python Numpy Support: On
Python Numpy Path: C:\Program Files\ParaView 6.0.1\bin\lib\site-packages\numpy
Python Numpy Version: 1.26.4
Python Matplotlib Support: On
Python Matplotlib Path: C:\Program Files\ParaView 6.0.1\bin\lib\site-packages\matplotlib
Python Matplotlib Version: 3.7.2
Python Testing: Off
MPI Enabled: Off
ParaView Build ID: superbuild 8c0f929966f005396802f3b2957c734a6c68b3c1 (!1292)
Disable Registry: Off
Test Directory:
Data Directory:
SMP Backend: TBB
SMP Max Number of Threads: 20
OpenGL Vendor: NVIDIA Corporation
OpenGL Version: 3.2.0 NVIDIA 576.83
Connection Information:
Remote Connection: No
For 5.11:
Client Information:
Version: 5.11.0
VTK Version: 9.2.20220823
Qt Version: 5.15.2
Embedded Python: On
Python Library Path: C:\Program Files\ParaView 5.11.0\bin\lib
Python Library Version: 3.9.13 (tags/v3.9.13:6de2ca5, May 17 2022, 16:36:42) [MSC v.1929 64 bit (AMD64)]
Python Numpy Path: C:\Program Files\ParaView 5.11.0\bin\Lib\site-packages\numpy
Python Numpy Version: 1.21.1
Python Matplotlib Path: C:\Program Files\ParaView 5.11.0\bin\Lib\site-packages\matplotlib
Python Testing: Off
MPI Enabled: Off
ParaView Build ID: superbuild 296d2d1b237965dbf5059263bb6feac90417f250 (!1041)
Test Directory:
Data Directory:
SMP Backend: TBB
OpenGL Vendor: Intel
OpenGL Version: 3.2.0 - Build 32.0.101.6881
OpenGL Renderer: Intel(R) Iris(R) Xe Graphics
Thanks in advance.
In 5.11 you are somehow NOT using your GPU.
Maybe try doing that in 6.0.1 ?
Could you point me how to disable GPU usage in Paraview ?
This is not controlled by ParaView but by your system. Typically this should be done in NVidia Settings or Windows settings directly.
Indeed, deactivating the NVIDIA GPU temporary fixed the issue, as Paraview 6.0 now reports using Intel(R) Iris(R) Xe Graphics.
Do you think issuing a bug report in gitlab Paraview could help being able to use the GPU ?
this is probably a nvidia driver issue, not a ParaView issue. Please update your nvidia driver.
Issue solved by updating nvidia drivers.
Actually, the issue only appears when having a second screen plugged, even after updating GPU drivers.
FYI: I’ve tried 2 different screens without any difference.
If that can help, it seems that the whole GUI is affected. See attached video.
That points even more to a driver issue. No idea how to fix it though.
