ParaView AI policy
He folks, we have a proposal for a policy regarding contributions that use generative AI tools under review at https://gitlab.kitware.com/paraview/paraview/-/merge_requests/8044. You comments on the proposal here or in that merge request are welcome!
I think this is a good AI policy document. It is concise and has the direction that the ParaView developer community has been going: You can use generative AI, but you must understand everything you create and respect reviewer time.
If I have one minor criticism, it would be that item 5 for contributors is a little unclear.
  1. Always separate your contributions in different parts and merge them iteratively or separately to reduce the quantity of changes to aid for review, with a goal a maximum 1k lines change by MR
It is not really clear when and why you are separating your contributions. I think the point here, in addition to keeping MRs small, is to make sure all changes in an MR are on topic. Maybe reword as something like this:
  1. Limit every MR to a single topic by breaking large contributions into different parts that are merged separately, with a goal of a maximum 1k lines change per MR
(Ironically, MR !8044 breaks this rule by cramming an AI policy and a merge request template into a single MR. I would argue these should be split into two separate MRs.)
