I’m trying to use --multi-clients mode for a Client-Data-Server-Render-Server mode setup. I start the data server by using the following command:
pvdataserver --multi-clients
and I start the render server by using the following command:
pvrenderserver
I did not use the --multi-clients argument for pvrenderserver because I got the following error:
The following argument was not expected: --multi-clients
After starting both servers, I started the ParaView Desktop GUI client and connected to both servers successfully. However, upon starting a new instantiation of ParaView Desktop GUI client and trying to join as another user (to test multi-users), I got the following error log.
Everything is running on the same machine and I have successfully tested multi-clients with pvserver.
