Hello
I have data generated from Converge CFD solver which is about 12 gb in size. I am using Paraview 5.10.1 on mac os monterey 12.5.1. I am facing the following difficulty on both windwos and mac os machines.
I could see MPI on both the machines but I am unable to see how many cores paraview is using in both the machines,
I read the data file with convergecfd reader and it takes a few minutes to read the data, when I apply celltopointdata filter it takes a few more minutes to get render the visualization, On top of this if I apply clip filter using either a plane or a box with specified dimensions paraview stops responding and I have to force quit the paraview.
I am not sure what’s happening with the clip filter. Any help is appreciated.
I left it the whole night and still, it did not finish the process… its about 8 to 9 hrs duration. By the way, could you help me run the paraview on a multicore processor as well? How do I run praview in parallel on a multicore processor. I also tried running the binary version of paraview on our hpc and it was giving the following error
qt.qpa.plugin: Could not load the Qt platform plugin “xcb” in “” even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: xcb.
error: exception occurred: Subprocess aborted
I have used anaconda-based enviroment, used spack to install paraview on my HPC but none of them worked.
