Paraview Compilation Errors with Catalyst enabled [Paraview 5.13.0-RC2]
I am having errors compiling ParaView with the -DPARAVIEW_ENABLE_CATALYST=ON .
I am compiling with gcc 11.2.0.
Without catalyst it builds fine. With catalyst I get the following error. Any Ideas?
paraview/master/src/paraview/VTK/ThirdParty/ioss/vtkioss/catalyst/Iocatalyst_DatabaseIO.C: In member function ‘std::vector<INT> vtkioss_Iocatalyst::DatabaseIO::ImplementationT::getInterweavedScalarDataFromConduitNode(std::vector<std::__cxx11::basic_string<char> >, conduit_cpp::Node&) const’:
paraview/master/src/paraview/VTK/ThirdParty/ioss/vtkioss/catalyst/Iocatalyst_DatabaseIO.C:881:39: error: ‘class conduit_cpp::Node’ has no member named ‘number_of_elements’
  881 |       int            num_get = t_node.number_of_elements();
There were some fixes in the final 5.13 version related to Ioss. You may want to try the v5.13.0 tag instead of the RC2.
Unfortunately the error persists in 5.13.0 as well.
In 5.12.1, 5.12.0 I get the following error
In file included from usr/shared/tools/centos/7/catalyst/HPCX/2.0.0/include/catalyst-2.0/conduit.h:19,
paraview/master/src/paraview/Clients/InSitu/vtkInSituInitializationHelper.cxx:9:
centos/7/catalyst/HPCX/2.0.0/include/catalyst-2.0/conduit_node.h:35:15: error: conflicting declaration ‘typedef void conduit_node’
   35 | typedef void  conduit_node;
In file included from paraview/master/src/paraview/Clients/InSitu/vtkInSituInitializationHelper.cxx:3:
paraview/master/src/paraview/Clients/InSitu/vtkInSituInitializationHelper.h:45:34: note: previous declaration as ‘typedef struct conduit_node_impl conduit_node’
   45 | typedef struct conduit_node_impl conduit_node;
make[2]: *** [Clients/InSitu/CMakeFiles/InSitu.dir/vtkInSituInitializationHelper.cxx.o] Error 1
make[1]: *** [Clients/InSitu/CMakeFiles/InSitu.dir/all] Error 2
make: *** [all] Error 2
I think that Catalyst install is out of date here. I changed this typedef in Conduit 0.8.0 (via this PR). This was pulled into Catalyst 2.0.0-rc1 via this MR. Where is this Catalyst from? It seems to be a pre-RC build rather than a full release.
Thanks.
I was using a very old catalyst. With the new catalyst-2.0.0 I was able to build 5.13.0 successfully
