cavity - Copy.zip (1.1 MB) Greetings,
I used Paraview to view my Openfoam results. It crashed when I changed time step. I tried different versions of Paraview. And it did not work.
Could you give me some hints what I can do? Is is openfoam problem or paraview problem?
Thank you!
olesenm
(Mark)
#2
Hi @devinInOttawa - welcome to the ParaView (and OpenFOAM) community!
The cause looks pretty obvious to me - see issue 18103
For now, the only obvious (ugly) workaround is to remove those files I guess. Not a satisfying answer, I know.
Cheers,
/mark
