Hello, the paraview version is 5.9.1, when I slice the modal in normal z direction, paraview crashes immediately without any prompt, could someone help me fix this issue? The file is attached below. Thanks a lot.
Please update to last release
Thansk for your kind reply. I used paraview 5.12.0, but paraview also crushes immediately.
Hello, could someone help me fix this issue?
Thanks for providing your data. I am unable to reproduce the crash with ParaView 5.12.0 on macOS with builtin server.
Attached is the ParaView state file I tested. xq_slice_state.pvsm (307.4 KB) It loads the file you shared and then applies a Slice filter aligned with the Z-normal at the default Origin. Does that match what you are doing?
Thanks a lot, that’s what I need. But I used your xq_slice_state.pvsm file in my computer, paraview also crushes immediately. I installed the paraview 5.12.0 in windows, and I don’t know why this happened.
Let’s try something else. Try Edit menu → Reset to Default Settings and restart ParaView. Then try again.
Interesting. It completes successfully for me with or without Triangulate the slice checked, so if there is an error, I am perhaps getting lucky not hitting it on my system.
Uncheck the “Show Plane” checkbox and the widgets will disappear.
