Hi all,
I am using OpenFOAM only to create a mesh (using blockmesh and snappyhexmesh), to simulate the flow around a vehicle in other software (code_saturne) using FVM. It is a mesh of around 40 million cells. I would like to be able to visualize the mesh using ParaFOAM (or Paraview), prior to using code_saturne.
The problem is that when I run ParaFOAM (or Paraview, and loading the *.foam file), during the loading process the case closes, either from my own PC or from a server with a lot of RAM (in case that was the cause). I did the latter since I have NO problems seeing a mesh of about 10 million cells.
I show four different messages: when using ParaFOAM/Paraview in my PC and in a remote server
Using Paraview in my PC:
Gtk-Message: 15:40:31.656: Failed to load module “canberra-gtk-module”
AutoMPI: SUCCESS: command is:
“/usr/bin/mpiexec” “-np” “4” “/usr/lib/paraview/pvserver” “–server-port=37021”
AutoMPI: starting process server
-------------- server output --------------
Waiting for client…
AutoMPI: server successfully started.
ERROR: In /build/paraview-lH8wFv/paraview-5.4.1+dfsg3/VTK/Common/System/vtkSocket.cxx, line 572
vtkClientSocket (0x55b55ee3dac0): Socket error in call to send. Tubería rota.ERROR: In /build/paraview-lH8wFv/paraview-5.4.1+dfsg3/VTK/Common/System/vtkSocket.cxx, line 572
vtkClientSocket (0x55b55ee3dac0): Socket error in call to send. Tubería rota.ERROR: In /build/paraview-lH8wFv/paraview-5.4.1+dfsg3/ParaViewCore/ServerManager/Core/vtkSMSessionClient.cxx, line 786
vtkSMSessionClient (0x55b55e3cac70): Server failed to gather information.ERROR: In /build/paraview-lH8wFv/paraview-5.4.1+dfsg3/VTK/Common/System/vtkSocket.cxx, line 572
vtkClientSocket (0x55b55ee3dac0): Socket error in call to send. Tubería rota.paraview: /build/paraview-lH8wFv/paraview-5.4.1+dfsg3/VTK/Parallel/Core/vtkMultiProcessStream.cxx:777: vtkMultiProcessStream& vtkMultiProcessStream::operator>>(std::__cxx11::string&): La declaración
this->Internals->Data.front() == vtkInternals::string_value' no se cumple. Abortado (core’ generado)
Using ParaFOAM in my PC:
Segmentation fault (core dumped)
Using Paraview from a remote server:
[cluster62:110445] *** Process received signal ***
[cluster62:110445] Signal: Violaci�n de segmento (11)
[cluster62:110445] Signal code: Address not mapped (1)
[cluster62:110445] Failing at address: 0x7115000
[cluster62:110445] [ 0] /lib64/libpthread.so.0[0x3d8ac0f7e0]
[cluster62:110445] [ 1] /lib64/libc.so.6(memcpy+0x292)[0x3d8a0899b2]
[cluster62:110445] [ 2] /share/apps/paraview/5.6.0/lib/libvtkIOGeometry-pv5.6.so.1(+0x149788)[0x7fb5e11a0788]
[cluster62:110445] [ 3] /share/apps/paraview/5.6.0/lib/libvtkIOGeometry-pv5.6.so.1(+0x14b091)[0x7fb5e11a2091]
[cluster62:110445] [ 4] /share/apps/paraview/5.6.0/lib/libvtkIOGeometry-pv5.6.so.1(+0x12a004)[0x7fb5e1181004]
[cluster62:110445] [ 5] /share/apps/paraview/5.6.0/lib/libvtkIOGeometry-pv5.6.so.1(+0x13d146)[0x7fb5e1194146]
[cluster62:110445] [ 6] /share/apps/paraview/5.6.0/lib/libvtkIOGeometry-pv5.6.so.1(ZN17vtkOpenFOAMReader11RequestDataEP14vtkInformationPP20vtkInformationVectorS3+0x5cf)[0x7fb5e1196c4d]
[cluster62:110445] [ 7] /share/apps/paraview/5.6.0/lib/libvtkIOParallel-pv5.6.so.1(ZN18vtkPOpenFOAMReader11RequestDataEP14vtkInformationPP20vtkInformationVectorS3+0x55)[0x7fb5e1aa6ec3]
[cluster62:110445] [ 8] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN29vtkMultiBlockDataSetAlgorithm14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0xa1)[0x7fb5d8ddfe61]
[cluster62:110445] [ 9] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN12vtkExecutive13CallAlgorithmEP14vtkInformationiPP20vtkInformationVectorS3+0x83)[0x7fb5d8dc6ee9]
[cluster62:110445] [10] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN23vtkDemandDrivenPipeline11ExecuteDataEP14vtkInformationPP20vtkInformationVectorS3+0x67)[0x7fb5d8dbf0b9]
[cluster62:110445] [11] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN24vtkCompositeDataPipeline11ExecuteDataEP14vtkInformationPP20vtkInformationVectorS3+0x492)[0x7fb5d8db5258]
[cluster62:110445] [12] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN23vtkDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0x46b)[0x7fb5d8dbe7e7]
[cluster62:110445] [13] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN32vtkStreamingDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0x932)[0x7fb5d8e0133c]
[cluster62:110445] [14] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(_ZN24vtkCompositeDataPipeline15ForwardUpstreamEP14vtkInformation+0x2d8)[0x7fb5d8db792e]
[cluster62:110445] [15] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN23vtkDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0x3da)[0x7fb5d8dbe756]
[cluster62:110445] [16] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN32vtkStreamingDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0x932)[0x7fb5d8e0133c]
[cluster62:110445] [17] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(_ZN23vtkDemandDrivenPipeline10UpdateDataEi+0x315)[0x7fb5d8dbef15]
[cluster62:110445] [18] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(_ZN32vtkStreamingDemandDrivenPipeline6UpdateEiP20vtkInformationVector+0x172)[0x7fb5d8e0164a]
[cluster62:110445] [19] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(_ZN32vtkStreamingDemandDrivenPipeline6UpdateEi+0x30)[0x7fb5d8e014d6]
[cluster62:110445] [20] /share/apps/paraview/5.6.0/lib/libvtkPVServerImplementationCore-pv5.6.so.1(_ZN16vtkSISourceProxy14UpdatePipelineEidb+0x1b8)[0x7fb5e8ad8b94]
[cluster62:110445] [21] /share/apps/paraview/5.6.0/lib/libvtkPVServerManagerApplication-pv5.6.so.1(_Z23vtkSISourceProxyCommandP26vtkClientServerInterpreterP13vtkObjectBasePKcRK21vtkClientServerStreamRS5_Pv+0x712)[0x7fb5ec096082]
[cluster62:110445] [22] /share/apps/paraview/5.6.0/lib/libvtkClientServer-pv5.6.so.1(ZN26vtkClientServerInterpreter19CallCommandFunctionEPKcP13vtkObjectBaseS1_RK21vtkClientServerStreamRS4+0x315)[0x7fb5e6b5986f]
[cluster62:110445] [23] /share/apps/paraview/5.6.0/lib/libvtkClientServer-pv5.6.so.1(_ZN26vtkClientServerInterpreter20ProcessCommandInvokeERK21vtkClientServerStreami+0x1c5)[0x7fb5e6b58043]
[cluster62:110445] [24] /share/apps/paraview/5.6.0/lib/libvtkClientServer-pv5.6.so.1(_ZN26vtkClientServerInterpreter17ProcessOneMessageERK21vtkClientServerStreami+0x135)[0x7fb5e6b5764d]
[cluster62:110445] [25] /share/apps/paraview/5.6.0/lib/libvtkClientServer-pv5.6.so.1(_ZN26vtkClientServerInterpreter13ProcessStreamERK21vtkClientServerStream+0x2f)[0x7fb5e6b574e7]
[cluster62:110445] [26] /share/apps/paraview/5.6.0/lib/libvtkPVServerImplementationCore-pv5.6.so.1(_ZN16vtkPVSessionCore21ExecuteStreamInternalERK21vtkClientServerStreamb+0xde)[0x7fb5e8a8b2d4]
[cluster62:110445] [27] /share/apps/paraview/5.6.0/lib/libvtkPVServerImplementationCore-pv5.6.so.1(_ZN16vtkPVSessionCore13ExecuteStreamEjRK21vtkClientServerStreamb+0x1f5)[0x7fb5e8a8b0d3]
[cluster62:110445] [28] /share/apps/paraview/5.6.0/lib/libvtkPVServerImplementationCore-pv5.6.so.1(_ZN16vtkPVSessionBase13ExecuteStreamEjRK21vtkClientServerStreamb+0x5a)[0x7fb5e8a87700]
[cluster62:110445] [29] /share/apps/paraview/5.6.0/lib/libvtkPVServerManagerCore-pv5.6.so.1(_ZN10vtkSMProxy13ExecuteStreamERK21vtkClientServerStreambj+0xaa)[0x7fb5e8f5bad6]
[cluster62:110445] *** End of error message ***
Using ParaFOAM from a remote server:
[cluster62:115389] *** Process received signal ***
[cluster62:115389] Signal: Segmentation fault (11)
[cluster62:115389] Signal code: Address not mapped (1)
[cluster62:115389] Failing at address: 0x6ed6000
[cluster62:115389] [ 0] /lib64/libpthread.so.0[0x3d8ac0f7e0]
[cluster62:115389] [ 1] /lib64/libc.so.6(memcpy+0x2e3)[0x3d8a089a03]
[cluster62:115389] [ 2] /share/apps/paraview/5.6.0/lib/libvtkIOGeometry-pv5.6.so.1(+0x149788)[0x7fcf8a9d7788]
[cluster62:115389] [ 3] /share/apps/paraview/5.6.0/lib/libvtkIOGeometry-pv5.6.so.1(+0x14b091)[0x7fcf8a9d9091]
[cluster62:115389] [ 4] /share/apps/paraview/5.6.0/lib/libvtkIOGeometry-pv5.6.so.1(+0x12a004)[0x7fcf8a9b8004]
[cluster62:115389] [ 5] /share/apps/paraview/5.6.0/lib/libvtkIOGeometry-pv5.6.so.1(+0x13d146)[0x7fcf8a9cb146]
[cluster62:115389] [ 6] /share/apps/paraview/5.6.0/lib/libvtkIOGeometry-pv5.6.so.1(ZN17vtkOpenFOAMReader11RequestDataEP14vtkInformationPP20vtkInformationVectorS3+0x5cf)[0x7fcf8a9cdc4d]
[cluster62:115389] [ 7] /share/apps/paraview/5.6.0/lib/libvtkIOParallel-pv5.6.so.1(ZN18vtkPOpenFOAMReader11RequestDataEP14vtkInformationPP20vtkInformationVectorS3+0x55)[0x7fcf8b2ddec3]
[cluster62:115389] [ 8] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN29vtkMultiBlockDataSetAlgorithm14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0xa1)[0x7fcf82615e61]
[cluster62:115389] [ 9] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN12vtkExecutive13CallAlgorithmEP14vtkInformationiPP20vtkInformationVectorS3+0x83)[0x7fcf825fcee9]
[cluster62:115389] [10] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN23vtkDemandDrivenPipeline11ExecuteDataEP14vtkInformationPP20vtkInformationVectorS3+0x67)[0x7fcf825f50b9]
[cluster62:115389] [11] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN24vtkCompositeDataPipeline11ExecuteDataEP14vtkInformationPP20vtkInformationVectorS3+0x492)[0x7fcf825eb258]
[cluster62:115389] [12] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN23vtkDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0x46b)[0x7fcf825f47e7]
[cluster62:115389] [13] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN32vtkStreamingDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0x932)[0x7fcf8263733c]
[cluster62:115389] [14] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(_ZN24vtkCompositeDataPipeline15ForwardUpstreamEP14vtkInformation+0x2d8)[0x7fcf825ed92e]
[cluster62:115389] [15] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN23vtkDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0x3da)[0x7fcf825f4756]
[cluster62:115389] [16] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(ZN32vtkStreamingDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3+0x932)[0x7fcf8263733c]
[cluster62:115389] [17] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(_ZN23vtkDemandDrivenPipeline10UpdateDataEi+0x315)[0x7fcf825f4f15]
[cluster62:115389] [18] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(_ZN32vtkStreamingDemandDrivenPipeline6UpdateEiP20vtkInformationVector+0x172)[0x7fcf8263764a]
[cluster62:115389] [19] /share/apps/paraview/5.6.0/lib/libvtkCommonExecutionModel-pv5.6.so.1(_ZN32vtkStreamingDemandDrivenPipeline6UpdateEi+0x30)[0x7fcf826374d6]
[cluster62:115389] [20] /share/apps/paraview/5.6.0/lib/libvtkPVServerImplementationCore-pv5.6.so.1(_ZN16vtkSISourceProxy14UpdatePipelineEidb+0x1b8)[0x7fcf9230eb94]
[cluster62:115389] [21] /share/apps/paraview/5.6.0/lib/libvtkPVServerManagerApplication-pv5.6.so.1(_Z23vtkSISourceProxyCommandP26vtkClientServerInterpreterP13vtkObjectBasePKcRK21vtkClientServerStreamRS5_Pv+0x712)[0x7fcf958cd082]
[cluster62:115389] [22] /share/apps/paraview/5.6.0/lib/libvtkClientServer-pv5.6.so.1(ZN26vtkClientServerInterpreter19CallCommandFunctionEPKcP13vtkObjectBaseS1_RK21vtkClientServerStreamRS4+0x315)[0x7fcf9038f86f]
[cluster62:115389] [23] /share/apps/paraview/5.6.0/lib/libvtkClientServer-pv5.6.so.1(_ZN26vtkClientServerInterpreter20ProcessCommandInvokeERK21vtkClientServerStreami+0x1c5)[0x7fcf9038e043]
[cluster62:115389] [24] /share/apps/paraview/5.6.0/lib/libvtkClientServer-pv5.6.so.1(_ZN26vtkClientServerInterpreter17ProcessOneMessageERK21vtkClientServerStreami+0x135)[0x7fcf9038d64d]
[cluster62:115389] [25] /share/apps/paraview/5.6.0/lib/libvtkClientServer-pv5.6.so.1(_ZN26vtkClientServerInterpreter13ProcessStreamERK21vtkClientServerStream+0x2f)[0x7fcf9038d4e7]
[cluster62:115389] [26] /share/apps/paraview/5.6.0/lib/libvtkPVServerImplementationCore-pv5.6.so.1(_ZN16vtkPVSessionCore21ExecuteStreamInternalERK21vtkClientServerStreamb+0xde)[0x7fcf922c12d4]
[cluster62:115389] [27] /share/apps/paraview/5.6.0/lib/libvtkPVServerImplementationCore-pv5.6.so.1(_ZN16vtkPVSessionCore13ExecuteStreamEjRK21vtkClientServerStreamb+0x1f5)[0x7fcf922c10d3]
[cluster62:115389] [28] /share/apps/paraview/5.6.0/lib/libvtkPVServerImplementationCore-pv5.6.so.1(_ZN16vtkPVSessionBase13ExecuteStreamEjRK21vtkClientServerStreamb+0x5a)[0x7fcf922bd700]
[cluster62:115389] [29] /share/apps/paraview/5.6.0/lib/libvtkPVServerManagerCore-pv5.6.so.1(_ZN10vtkSMProxy13ExecuteStreamERK21vtkClientServerStreambj+0xaa)[0x7fcf92792ad6]
[cluster62:115389] *** End of error message ***
/share/apps/OpenFOAM/OpenFOAM-8/bin/paraFoam: line 63: 115389 Segmentation fault LD_LIBRARY_PATH=$LD_LIBRARY_PATH:ParaView_LIB_DIR/mesa paraview "@"
Versions of software:
OpenFOAM: v7 (.org) (for mesh creation; for ParaFOAM I tried to use versions 2.0 to 9.0)
Paraview: 5.4.1 (local computer) and 5.6.0 (remote server)
Any ideas on what could be the problem?
