I was trying to use Paraview for visualization of a simple mesh data with 16 HEX8 elements and has 50 data set with nodal values and 5 set with cell values. It loads perfectly and also I can visualize the data set without any problem with ‘Surface’ turned on. But if I turn on the ‘Surface with Mesh’ then there is weird graphics issue that pops up. And if I select ‘Hover cells on’ to investigate the data of a particular cell, it crashes immediately. I have tried with some other mesh but same issue. CrashReport_Paraview.txt (136.4 KB)
Attached is the crash report from Mac.
Best
Subhendu Chakraborty
Los Alamos National Laboratory
The weird graphics are well reported. I haven’t heard about the crash, but I was able to replicate that on my Mac as well. I only got the crash if I was in Surface with Mesh mode. If I put it back in Surface mode, I did not see an issue. I expect the two issues are related.
