I am opening this topic because I am trying to load a large file (278MB) into paraview 5.9.1 on windows 11 and it keeps crashing.
I’ve read some similar issues here and so I checked the event viewer and the following event appears:
**-** **EventData**
**AppName** paraview.exe
**AppVersion** 0.0.0.0
**AppTimeStamp** 60a2bd00
**ModuleName** vtkFiltersGeometry-pv5.9.dll
**ModuleVersion** 0.0.0.0
**ModuleTimeStamp** 60a2b5fe
**ExceptionCode** c0000005
**FaultingOffset** 000000000000c2ee
**ProcessId** 0x3328
**ProcessCreationTime** 0x1d913d7de2b0069
**AppPath** C:\Program Files\ParaView 5.9.1-Windows-Python3.8-msvc2017-64bit\bin\paraview.exe
**ModulePath** C:\Program Files\ParaView 5.9.1-Windows-Python3.8-msvc2017-64bit\bin\vtkFiltersGeometry-pv5.9.dll
**IntegratorReportId** df143688-3877-40a1-b3dd-c70cc801befa
**PackageFullName**
**PackageRelativeAppId**
I have also tried opening a smaller file (41,1 MB), but it crashes again. Significantly smaller files can be opened without issues.
I have already reset the app to default settings, tried to update my graphic drivers and checked the task manager in case it’s a memory problem, but nothing changed.
This is the information of the About dialog in the paraview app, in case it helps :
Client Information:
Version: 5.9.1
VTK Version:
Qt Version: 5.15.1
vtkIdType size: 64bits
Embedded Python: On
Python Library Path: C:\Program Files\ParaView 5.9.1-Windows-Python3.8-msvc2017-64bit\bin\lib
Python Library Version: 3.8.6 (tags/v3.8.6:db45529, Sep 23 2020, 15:52:53) [MSC v.1927 64 bit (AMD64)]
Python Numpy Support: On
Python Numpy Path: C:\Program Files\ParaView 5.9.1-Windows-Python3.8-msvc2017-64bit\bin\Lib\site-packages\numpy
Python Numpy Version: 1.19.2
Python Matplotlib Support: On
Python Matplotlib Path: C:\Program Files\ParaView 5.9.1-Windows-Python3.8-msvc2017-64bit\bin\Lib\site-packages\matplotlib
Python Testing: Off
MPI Enabled: Off
Disable Registry: Off
Test Directory:
Data Directory:
OpenGL Vendor: Intel
OpenGL Version: 3.2.0 - Build 31.0.101.1999
OpenGL Renderer: Intel(R) UHD Graphics
Connection Information:
Remote Connection: No
Any help would be greatly appreciated. Thanks in advance.
