Paraview crashing when I use lagrangian particle tracker
Hello everyone,
I am studying a plume impingement and visualizing my openFOAM plume results in paraview (only the last time step of my simulation). Since I wanted to calculate particle path according to the flowfield, also taking forces into account, and trying to do a one way coupling of the
flowfield and ground particles,I am using the lagrangian particle tracker.
However, I am having some issues in that. I am applying the lagrangian seed helper to my case .foam and specified the initial velocity as 0, along with a particle diameter, density, and initial integration time. Then I apply the Lagrangian Particle Tracker, selecting the velocity field as the input flow field and the Seed Helper output as the particle seeds.
The problem is, I can see the particles, but they don’t move…
It might be the initial velocity I put as 0? However, when I switch to flow interpolation, ParaView crashes.
Has anyone encountered this problem before, or does anyone know how I can resolve it?
Are you sure the stream tracer doesnt fit what you need ? The LPT is very complex to use.
In any case, please share your date.
Thank you for your answer!
I don’t know if stream tracer can be useful for me..I understood that it shows how massless particles move through a vector field, am I correct? While I want to take mass and density into account for the trajectories.
I see it’s a bit complicate and I couldn’t find any tutorials or tips, the only one I found explains what it does in a very general way but probably every case is different and I am doing something wrong which I don’t know…
Anyway, what would I need to share?
Your volume containing the fields, the particle seeds and the surface of interactions if any.
https://www.kitware.com/vtk-and-paraview-add-highly-configurable-particle-tracker/
Unfortunately, I cannot share the dataset.
My simulation domain is a wedge that models a thruster + a rectangular plume domain. So my idea was to inject particles on the ground surface (like mars ground) and see where they go according to my flowfield. I am releasing the particles with a line source on the ground (but i also tried the cloud) with data from martian regolith, I don’t know if it makes sense for what the filter was designed for.
In case I also tried to inject particles from the inlet and throat of the thruster to see if they move at all but nothing happens.
When I do that, the ParticlesPath shows me the particles on a line while the ParticleInterations is empty (in all the cases i tried).
Also, I saw that website and I undertstand the general procedure, but I am still stuck…
Then you may want to reach out to Kitware for professional support: Get Support - Kitware Europe
alright, thank you anyway!
additionally, i would like to ask you something else if it’s ok. Whenever i apply the filter CleanCellsToGrid with a lot of time steps it crashes. is there an alternative to that or something else I could to to avoid that?
Without data to reproduce, I cant really reproduce so i cant suggest alternative because I cant figure out why it is failing.
