Hello everyone, just encountered an unusual error
paraview version 5.4.1 - installed from Ubuntu repository (Ubuntu 18.04.4 LTS) crushes upon the opening stack of TIFFs when MPI is on (see the error message below)
if MPI is off the process it works through, which looks like an interrupted connection
There were similar threads some years ago
https://www.paraview.org/pipermail/paraview-developers/2016-November/004908.html
https://www.paraview.org/pipermail/paraview-developers/2016-November/004909.html
but the solution of the bugs was not clear …
srv:~/ParaView-5.8.0-MPI-Linux-Python2.7-64bit$ paraview --mpi
AutoMPI: SUCCESS: command is:
“/usr/bin/mpiexec” “-np” “10” “/usr/lib/paraview/pvserver” “–server-port=35427”
AutoMPI: starting process server
-------------- server output --------------
Waiting for client…
AutoMPI: server successfully started.
ERROR: In /build/paraview-lH8wFv/paraview-5.4.1+dfsg3/VTK/Common/System/vtkSocket.cxx, line 572
vtkClientSocket (0x55fe569f42e0): Socket error in call to send. Broken pipe.
ERROR: In /build/paraview-lH8wFv/paraview-5.4.1+dfsg3/ParaViewCore/ServerManager/Core/vtkSMSessionClient.cxx, line 786
vtkSMSessionClient (0x55fe55f748f0): Server failed to gather information.
paraview: /build/paraview-lH8wFv/paraview-5.4.1+dfsg3/VTK/Parallel/Core/vtkMultiProcessStream.cxx:777: vtkMultiProcessStream& vtkMultiProcessStream::operator>>(std::__cxx11::string&): Assertion `this->Internals->Data.front() == vtkInternals::string_value’ failed.
[kitdatasrv:10195] *** Process received signal ***
[kitdatasrv:10195] Signal: Aborted (6)
[kitdatasrv:10195] Signal code: (-6)
[kitdatasrv:10195] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3efd0)[0x7f6ba2f57fd0]
[kitdatasrv:10195] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f6ba2f57f47]
[kitdatasrv:10195] [ 2] /lib/x86_64-linux-gnu/libc.so.6(abort+0x141)[0x7f6ba2f598b1]
[kitdatasrv:10195] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x3042a)[0x7f6ba2f4942a]
[kitdatasrv:10195] [ 4] /lib/x86_64-linux-gnu/libc.so.6(+0x304a2)[0x7f6ba2f494a2]
[kitdatasrv:10195] [ 5] /usr/lib/paraview/libvtkParallelCore.so.1(+0x27db5)[0x7f6b98cb4db5]
[kitdatasrv:10195] [ 6] /usr/lib/paraview/libvtkPVServerManagerCore.so.1(_ZN18vtkSMSessionClient9PullStateEPN17paraview_protobuf7MessageE+0x14b)[0x7f6ba498f78b]
[kitdatasrv:10195] [ 7] /usr/lib/paraview/libvtkPVServerManagerCore.so.1(_ZN17vtkSMRemoteObject9PullStateEPN17paraview_protobuf7MessageE+0x95)[0x7f6ba497e395]
[kitdatasrv:10195] [ 8] /usr/lib/paraview/libvtkPVServerManagerCore.so.1(_ZN10vtkSMProxy33UpdatePropertyInformationInternalEP13vtkSMProperty+0x22c)[0x7f6ba495ab7c]
[kitdatasrv:10195] [ 9] /usr/lib/paraview/libvtkPVServerManagerCore.so.1(_ZN10vtkSMProxy25UpdatePropertyInformationEv+0x14)[0x7f6ba49510b4]
[kitdatasrv:10195] [10] /usr/lib/paraview/libvtkPVServerManagerCore.so.1(_ZN16vtkSMSourceProxy25UpdatePipelineInformationEv+0x8c)[0x7f6ba49ad29c]
[kitdatasrv:10195] [11] /usr/lib/paraview/libvtkPVServerManagerCore.so.1(_ZN10vtkSMProxy25UpdatePipelineInformationEv+0x2d)[0x7f6ba495112d]
[kitdatasrv:10195] [12] /usr/lib/paraview/libvtkPVServerManagerCore.so.1(_ZN16vtkSMSourceProxy25UpdatePipelineInformationEv+0x8c)[0x7f6ba49ad29c]
[kitdatasrv:10195] [13] /usr/lib/paraview/libvtkpqComponents.so.1(_ZN17pqPropertiesPanel5applyEv+0x4f2)[0x7f6ba5872aa2]
[kitdatasrv:10195] [14] /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN11QMetaObject8activateEP7QObjectPKS_iPPv+0x4d0)[0x7f6ba41cef70]
[kitdatasrv:10195] [15] /usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN15QAbstractButton7clickedEb+0x42)[0x7f6ba66e2632]
[kitdatasrv:10195] [16] /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x59fc33)[0x7f6ba6417c33]
[kitdatasrv:10195] [17] /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x5a0fe4)[0x7f6ba6418fe4]
[kitdatasrv:10195] [18] /usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN15QAbstractButton17mouseReleaseEventEP11QMouseEvent+0x74)[0x7f6ba64190f4]
[kitdatasrv:10195] [19] /usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN7QWidget5eventEP6QEvent+0x2a0)[0x7f6ba6093930]
[kitdatasrv:10195] [20] /usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent+0x8c)[0x7f6ba603d03c]
[kitdatasrv:10195] [21] /usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN12QApplication6notifyEP7QObjectP6QEvent+0x476)[0x7f6ba6044136]
[kitdatasrv:10195] [22] /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN16QCoreApplication14notifyInternalEP7QObjectP6QEvent+0x8d)[0x7f6ba41ba8ad]
[kitdatasrv:10195] [23] /usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN19QApplicationPrivate14sendMouseEventEP7QWidgetP11QMouseEventS1_S1_PS1_R8QPointerIS0_Eb+0x14d)[0x7f6ba604373d]
[kitdatasrv:10195] [24] /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x249452)[0x7f6ba60c1452]
[kitdatasrv:10195] [25] /usr/lib/x86_64-linux-gnu/libQtGui.so.4(_ZN12QApplication15x11ProcessEventEP7_XEvent+0x16b3)[0x7f6ba60c0ce3]
[kitdatasrv:10195] [26] /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x272592)[0x7f6ba60ea592]
[kitdatasrv:10195] [27] /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x2e7)[0x7f6b9fefc417]
[kitdatasrv:10195] [28] /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x4c650)[0x7f6b9fefc650]
[kitdatasrv:10195] [29] /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2c)[0x7f6b9fefc6dc]
[kitdatasrv:10195] *** End of error message ***
Aborted (core dumped)
