PARAVIEW_DATA_EXCLUDE_FROM_ALL not working ?
Is there a way to disable the download step ? Since we are using a vtk 8.0.1, we are now getting “HTTP response code said error” errors during the ExternalData downloading step.
I have set these two variables but i’m still getting errors.
PARAVIEW_DATA_EXCLUDE_FROM_ALL:BOOL=ON
VTK_DATA_EXCLUDE_FROM_ALL:BOOL=ON
thank you
Do you have any recommendations, @brad.king?
FWIW the last URL that reported Couldn't connect to server does exist here. CMake should know how to follow the http-to-https redirect during download. The download should succeed.
One could turn off BUILD_TESTING completely to avoid getting any test data downloaded.
According to local testing, VTK_DATA_EXCLUDE_FROM_ALL and PARAVIEW_DATA_EXCLUDE_FROM_ALL exclude dependencies on the VTKData and ParaViewData targets except from some source packaging targets. I’d need more information about how to reproduce the problem to help further:
  • With what version of ParaView did you try to use VTK 8.0.1? How was the source tree prepared?
  • What “cmake” command line was used to generate the build tree?
  • What build command (e.g. “make”) was used to build it?
We are using Paraview 5.3 with VTK 8.0.1
cmake -G Ninja
-DPARAVIEW_ENABLE_CATALYST=OFF
-DITK_DIR=/home/buildbot/itk/build
-DOPENGL_gl_LIBRARY=/home/buildbot/local/lib/libGL.so
-DModule_vtkIOPLY=ON
-DPARAVIEW_QT_VERSION=5
-DOPENGL_INCLUDE_DIR=/home/buildbot/local/include
-DCTEST_USE_LAUNCHERS=TRUE
-DOSMESA_LIBRARY=/home/buildbot/local/lib/libOSMesa.so
-DCMAKE_BUILD_TYPE=Release
-DVTK_USE_X=ON
-DBUILD_TESTING=ON
-DVTK_OPENGL_HAS_OSMESA=ON
-DBUILD_SHARED_LIBS=ON
-DPARAVIEW_ENABLE_PYTHON=ON
-DCTEST_MODEL=Experimental
-DPARAVIEW_ENABLE_WEB=OFF
-DVTK_USE_OFFSCREEN=ON
-DOPENGL_xmesa_INCLUDE_DIR:PATH=IGNORE
-DOPENGL_glu_LIBRARY:FILEPATH=IGNORE
-B/worker/project-Test/project_build
-H/worker/project-Test/project
-DPARAVIEW_DATA_EXCLUDE_FROM_ALL:BOOL=ON
-DVTK_DATA_EXCLUDE_FROM_ALL:BOOL=ON
build command :
ctest -S /worker/project-Test/dashboard/dashboard.cmake -R Testproject ‘-DCTEST_CMAKE_GENERATOR=“Ninja”’ -DCTEST_TEST_TIMEOUT:STRING=250 -DCTEST_SOURCE_DIRECTORY:PATH=/worker/project-Test/project -DCTEST_BINARY_DIRECTORY:PATH=/worker/project-Test/project_build -DCTEST_MODEL:STRING=Experimental -DCTEST_BUILD_BUILDER_NAME:STRING=project-Test -DCTEST_BUILD_NUMBER:STRING=377 -DCTEST_SITE:STRING=projectDockerAWS -Dctest_parallel_level:STRING=24
I am currently moving my cmake configure/build/test logic to my dashboard cmake. I am trying to replicate the ParaView flow from open.cdash
I need the BUILD_TESTING since I am testing our state file.
Is there a way to make the ExternalData step give a warning instead of producing an error. My temporary solution was to deactivate the download functions in paraview/cmake/ExternalData.cmake
Setting PARAVIEW_DATA_EXCLUDE_FROM_ALL:BOOL=ON worked for me yesterday.
