Dear All,
I want to export a plot from ParaView to be able to import to Google Earth Pro. How can I do that?
Thank you all
Dear All,
Thank you all
As you may know, Google Earth can import either GPX or KML files.
You might also be able to directly import the CSV file into Google Earth, I haven’t tried to do this.
There are two ways to get the GPX file:
The easiest way is to export Longitude, Latitude, Altitude as a CSV file and then use GPSBabel with a command similar to:
gpsbabel -i unicsv -f input-file.csv -o gpx -F output-file.gpx
Alternatively, you can:
The GPX format is relatively simple. See GPS Exchange Format, additionally, there is a sample track there.
Also check out: How to convert a set of gps points to GPX file.
