Hi, I’ m trying to build myself paraview to be used with virtualgl glx, opengl and turbovnc.
I’ m trying to use spack recipe for that.
What currently happen is that within the current stack, I’ ve been able to build and run opengl demo, qt examples and vtk
The stack is also able to support the run of paraview 5.9.1 binary
unfortunately, my spack build of paraview 5.9.1 that use the same qt 5.15.2 fails with
warning: In unknown, line 0
warning: The X11 connection broke: No error (code 0)
XIO: fatal IO error 2 (No such file or directory) on X server “:24”
after 480 requests (444 known processed) with 0 events remaining.
So, any suggestion on where could be the problem would be really appreciated.
Also, would it be useful to find what has been used to produce the correctly runnning paraview binary from the site. I searched around but was not able to find the requirements, environment and config setup used for official paraview binary build.
For example, I see from the About panel that the Paraview binary is using internally provided Qt 5.12.9
is this a requirement?
Thanks in advance for any help
