I am using windows 11 with wsl ubunu22.04 and installed paraview with aptitude install paraview… but when I run paraview the following is the behaviour and paraview doesn’t start
( 1.161s) [paraview ]vtkOpenGLRenderWindow.c:499 ERR| vtkXOpenGLRenderWindow (0x55a9b0b58150): Unable to find a valid OpenGL 3.2 or later implementation. Please update your video card driver to the latest version. If you are using Mesa please make sure you have version 11.2 or later and make sure your driver in Mesa supports OpenGL 3.2 such as llvmpipe or openswr. If you are on windows and using Microsoft remote desktop note that it only supports OpenGL 3.2 with nvidia quadro cards. You can use other remoting software such as nomachine to avoid this issue.
( 2.050s) [paraview ]vtkOpenGLRenderWindow.c:499 ERR| vtkXOpenGLRenderWindow (0x55a9b24f5150): Unable to find a valid OpenGL 3.2 or later implementation. Please update your video card driver to the latest version. If you are using Mesa please make sure you have version 11.2 or later and make sure your driver in Mesa supports OpenGL 3.2 such as llvmpipe or openswr. If you are on windows and using Microsoft remote desktop note that it only supports OpenGL 3.2 with nvidia quadro cards. You can use other remoting software such as nomachine to avoid this issue.
Loguru caught a signal: SIGSEGV
Stack trace:
0 0x7f760142d520 /usr/bin/../lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7f760142d520]
( 2.337s) [paraview ] :0 FATL| Signal: SIGSEGV
[1]+ Segmentation fault paraview
