I have installed Paraview and can open it manually and it works fine. However, while trying to open it in wsl window I’m getting an error.
I tried the command paraFoam, paraFoam -touch later paraview& but I’m getting the same error.
I even tried the following commands to fix this issue but it didn’t work.
sudo cp /usr/lib/x86_64-linux-gnu/libQt5Core.so.5 /opt/paraviewopenfoam510/mesa/lib/
sudo strip --remove-section=.note.ABI-tag /opt/paraviewopenfoam510/mesa/lib/libQt5Core.so.5
One thing to add I have downloaded the paraview manually and I have 5.12.1 version, and have added it’s path in extended libraries list.
The command was working before the reinstallation of OpenFoam, I don’t understand why it’s giving this error now.
Hope to get some solution to this.
Thank you in advance
