gazzafield
(Garfield Tait)
February 23, 2024, 10:20am
1
I have installed Paraview Version 10 on Ubuntu v22.04LTS
When attempting to run Paraview for the first time:-
./bin/pvserver
The following error occurs:-
paraview: error while loading shared libraries: libpdal_base.so .13: cannot open shared object file: No such file or directory
I have tried to install libpdal_base13 however Ubuntu proudly reports that the latest version is already installed whixh is libpdal_base15.
mwestphal
(Mathieu Westphal (Kitware))
February 23, 2024, 10:25am
2
Please use latest ParaView binary release from https://paraview.org/download
gazzafield
(Garfield Tait)
February 23, 2024, 11:35am
3
Download latest release candidate. Extracted the file.
Entered the directory that was created:- ParaView-5.12.0-RC3-MPI-Linux-Python3.10-x86_64
cd bin
./paraview
No change. Same error.
mwestphal
February 23, 2024, 1:00pm
4
what is the output of printenv ?
ben.boeckel
(Ben Boeckel (Kitware))
February 26, 2024, 1:50am
5
I do not see any reference to libpdal_base.so.13 in the 5.12.0-RC3 package. Does running with the --dr flag work (i.e., paraview --dr)? If so, your configuration may be trying to load a plugin that was compiled against an older ParaView (where libpdal_base.so.13 did exist).
gazzafield
(Garfield Tait)
February 29, 2024, 8:10am
6
Output of printenv:-
SHELL=/bin/bash
LANGUAGE=en_GB:en
GTK_MODULES=appmenu-gtk-module
PWD=/media/8TB-LOCAL-VOLUME/User_Homes/tech/Downloads/ParaView-5.12.0-RC3-MPI-Linux-Python3.10-x86_64/bin
LOGNAME=tech
XDG_SESSION_TYPE=tty
MOTD_SHOWN=pam
HOME=/media/8TB-LOCAL-VOLUME/User_Homes/tech
LANG=en_GB.UTF-8
SSH_CONNECTION=130.209.26.149 49753 130.209.26.216 22
XDG_SESSION_CLASS=user
TERM=xterm-256color
LIBVIRT_DEFAULT_URI=qemu:///system
USER=tech
SHLVL=1
UBUNTU_MENUPROXY=1
XDG_SESSION_ID=357
XDG_RUNTIME_DIR=/run/user/1000
SSH_CLIENT=130.209.26.149 49753 22
XDG_DATA_DIRS=/media/8TB-LOCAL-VOLUME/User_Homes/tech/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share:/var/lib/snapd/desktop
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
SSH_TTY=/dev/pts/0
OLDPWD=/media/8TB-LOCAL-VOLUME/User_Homes/tech/Downloads/ParaView-5.12.0-RC3-MPI-Linux-Python3.10-x86_64
_=/usr/bin/printenv
gazzafield
(Garfield Tait)
February 29, 2024, 8:12am
7
Running pvserver or paravieww qith --dr makes no difference.
This is a fresh installation of Ubuntu v22.04 LTS (MATE) on a new Workstation with many and varied Apps and all updates installed. I have installed Paraview v5.10, which did not run correctly, and have downloaded the latest Release Candidate and tried that as suggested.
ben.boeckel
February 29, 2024, 11:20am
8
That is strange…we need to find what thinks it needs libpdal_base.so.13. Do you see any reference in the ParaView tree (grep -alR pdal_base /path/to/pv/extracted/package may result in some files; their paths and the output of readelf -d $path on each would be useful)?
If that comes up empty, tracing loaded libraries with LD_DEBUG=libs in the environment may provide hints as to what wants it in its output.
gazzafield
(Garfield Tait)
March 4, 2024, 3:17pm
9
Output of grep:-
grep -alR pdal_base /media/8TB-LOCAL-VOLUME/User_Homes/tech/Downloads/ParaView-5.12.0-RC3-MPI-Linux-Python3.10-x86_64
/media/8TB-LOCAL-VOLUME/User_Homes/tech/Downloads/ParaView-5.12.0-RC3-MPI-Linux-Python3.10-x86_64/lib/libvtkIOPDAL-pv5.12.so.1
/media/8TB-LOCAL-VOLUME/User_Homes/tech/Downloads/ParaView-5.12.0-RC3-MPI-Linux-Python3.10-x86_64/lib/libvtkIOPDAL-pv5.12.so.5.12
/media/8TB-LOCAL-VOLUME/User_Homes/tech/Downloads/ParaView-5.12.0-RC3-MPI-Linux-Python3.10-x86_64/lib/libpdal_base.so.15
/media/8TB-LOCAL-VOLUME/User_Homes/tech/Downloads/ParaView-5.12.0-RC3-MPI-Linux-Python3.10-x86_64/lib/libpdal_base.so.15.6.0
Is the command LD_DEBUG=libs simply run as that? If so, it returned nothing at all.
ben.boeckel
March 4, 2024, 5:33pm
10
Garfield Tait:
grep -alR pdal_base
OK; can you provide readelf -d $path on each result? These should all be .so.15, not .so.13.
gazzafield
(Garfield Tait)
March 5, 2024, 1:31pm
11
There’s A LOT of info on these so I have supplied the result of the first two:-
tech@Ubuntu-MATE-22:~$ readelf -d /media/8TB-LOCAL-VOLUME/User_Homes/tech/Downloads/ParaView-5.12.0-RC3-MPI-Linux-Python3.10-x86_64/lib/libvtkIOPDAL-pv5.12.so.1
Dynamic section at offset 0x13c30 contains 46 entries:
Tag Type Name/Value
0x0000000000000001 (NEEDED) Shared library: [libc.so.6]
0x0000000000000001 (NEEDED) Shared library: [libvtkFiltersGeneral-pv5.12.so.1]
0x0000000000000001 (NEEDED) Shared library: [libpdal_base.so.15]
0x0000000000000001 (NEEDED) Shared library: [libvtkFiltersCore-pv5.12.so.1]
0x0000000000000001 (NEEDED) Shared library: [libvtkCommonExecutionModel-pv5.12.so.1]
0x0000000000000001 (NEEDED) Shared library: [libvtkCommonDataModel-pv5.12.so.1]
0x0000000000000001 (NEEDED) Shared library: [libvtkCommonMisc-pv5.12.so.1]
0x0000000000000001 (NEEDED) Shared library: [libvtkCommonTransforms-pv5.12.so.1]
0x0000000000000001 (NEEDED) Shared library: [libvtkCommonMath-pv5.12.so.1]
0x0000000000000001 (NEEDED) Shared library: [libvtkkissfft-pv5.12.so.1]
0x0000000000000001 (NEEDED) Shared library: [libvtkCommonCore-pv5.12.so.1]
0x0000000000000001 (NEEDED) Shared library: [libvtktoken-pv5.12.so.1]
0x0000000000000001 (NEEDED) Shared library: [libpthread.so.0]
0x0000000000000001 (NEEDED) Shared library: [libtbb.so.12]
0x0000000000000001 (NEEDED) Shared library: [libgomp.so.1]
0x0000000000000001 (NEEDED) Shared library: [libvtksys-pv5.12.so.1]
0x0000000000000001 (NEEDED) Shared library: [libdl.so.2]
0x0000000000000001 (NEEDED) Shared library: [libpdal_util.so.15]
0x0000000000000001 (NEEDED) Shared library: [libstdc++.so.6]
0x0000000000000001 (NEEDED) Shared library: [libm.so.6]
0x0000000000000001 (NEEDED) Shared library: [libgcc_s.so.1]
0x000000000000000e (SONAME) Library soname: [libvtkIOPDAL-pv5.12.so.1]
0x000000000000000f (RPATH) Library rpath: [$ORIGIN:ORIGIN/../lib]
0x000000000000000c (INIT) 0x6000
0x000000000000000d (FINI) 0x10e78
0x0000000000000019 (INIT_ARRAY) 0x147b0
0x000000000000001b (INIT_ARRAYSZ) 16 (bytes)
0x000000000000001a (FINI_ARRAY) 0x147c0
0x000000000000001c (FINI_ARRAYSZ) 8 (bytes)
0x000000006ffffef5 (GNU_HASH) 0x260
0x0000000000000005 (STRTAB) 0x1790
0x0000000000000006 (SYMTAB) 0x338
0x000000000000000a (STRSZ) 8631 (bytes)
0x000000000000000b (SYMENT) 24 (bytes)
0x0000000000000003 (PLTGOT) 0x15000
0x0000000000000002 (PLTRELSZ) 2904 (bytes)
0x0000000000000014 (PLTREL) RELA
0x0000000000000017 (JMPREL) 0x4970
0x0000000000000007 (RELA) 0x3bc0
0x0000000000000008 (RELASZ) 3504 (bytes)
0x0000000000000009 (RELAENT) 24 (bytes)
0x000000006ffffffe (VERNEED) 0x3b00
0x000000006fffffff (VERNEEDNUM) 4
0x000000006ffffff0 (VERSYM) 0x3948
0x000000006ffffff9 (RELACOUNT) 43
0x0000000000000000 (NULL) 0x0
tech@Ubuntu-MATE-22:~ readelf -d /media/8TB-LOCAL-VOLUME/User_Homes/tech/Downloads/ParaView-5.12.0-RC3-MPI-Linux-Python3.10-x86_64/lib/libvtkIOPDAL-pv5.12.so.5.12
Tag Type Name/Value
mwestphal
March 7, 2024, 1:44pm
12
I confirm that the libs in the package are pointing to the right libpdal_base.so.15
Something else must be amiss in @gazzafield environnement.
