I am using paraview 5.8.1 version when i want to open xdmf file.Paraview.exe has stopped working and the software close why this happening please guide me.Thanks
Hi bilal,
Please update to the last version of ParaView (5.11.1): https://www.paraview.org/download/
Please share your file.
Best,
Hi Mathieu,
Thanks for your response,before i was using 5.7.1 this error come then i installed 5.8.1 error still exist ok now i try to install 5.11.1.I am sharing the file please check and guide me .
data_fluid.xdmf (369 Bytes)
I confirm that there is a crash with this file:
XDMF Error in /home/glow/dev/paraview/pv1/src/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfGrid.cxx line 772 (Grid has 0 children. Index 0 is out of range)
Thread 1 "paraview" received signal SIGSEGV, Segmentation fault.
0x00007fffdbb9d234 in xdmf2::XdmfGrid::GetGridType (this=0x0) at /home/glow/dev/paraview/pv1/src/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfGrid.h:184
184 XdmfGetValueMacro( GridType, XdmfInt32);
(gdb) bt
#0 0x00007fffdbb9d234 in xdmf2::XdmfGrid::GetGridType (this=0x0) at /home/glow/dev/paraview/pv1/src/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfGrid.h:184
#1 0x00007fffdbba6086 in vtkXdmfDomain::GetVTKDataType (this=0x55556079d8f0, xmfGrid=0x0) at /home/glow/dev/paraview/pv1/src/VTK/IO/Xdmf2/vtkXdmfReaderInternal.cxx:289
#2 0x00007fffdbba60d9 in vtkXdmfDomain::GetVTKDataType (this=0x55556079d8f0, xmfGrid=0x555560aa5088)
at /home/glow/dev/paraview/pv1/src/VTK/IO/Xdmf2/vtkXdmfReaderInternal.cxx:296
#3 0x00007fffdbba6060 in vtkXdmfDomain::GetVTKDataType (this=0x55556079d8f0) at /home/glow/dev/paraview/pv1/src/VTK/IO/Xdmf2/vtkXdmfReaderInternal.cxx:281
#4 0x00007fffdbb756cf in vtkXdmfReader::RequestDataObjectInternal (this=0x7fffc400a650, outputVector=0x55556089cff0)
at /home/glow/dev/paraview/pv1/src/VTK/IO/Xdmf2/vtkXdmfReader.cxx:307
#5 0x00007fffdbb746a4 in vtkXdmfReader::ProcessRequest (this=0x7fffc400a650, request=0x555560986600, inputVector=0x0, outputVector=0x55556089cff0)
at /home/glow/dev/paraview/pv1/src/VTK/IO/Xdmf2/vtkXdmfReader.cxx:215
#6 0x00007fffee99fe45 in vtkFileSeriesReader::ProcessRequest (this=0x5555595a6970, request=0x555560986600, inputVector=0x0, outputVector=0x55556089cff0)
at /home/glow/dev/paraview/pv1/src/VTKExtensions/IOCore/vtkFileSeriesReader.cxx:568
#7 0x00007ffff088b6d9 in vtkExecutive::CallAlgorithm (this=0x55556086ea50, request=0x555560986600, direction=1, inInfo=0x0, outInfo=0x55556089cff0)
at /home/glow/dev/paraview/pv1/src/VTK/Common/ExecutionModel/vtkExecutive.cxx:735
#8 0x00007ffff0873c90 in vtkCompositeDataPipeline::ExecuteDataObject (this=0x55556086ea50, request=0x555560986600, inInfoVec=0x0, outInfoVec=0x55556089cff0)
at /home/glow/dev/paraview/pv1/src/VTK/Common/ExecutionModel/vtkCompositeDataPipeline.cxx:115
#9 0x00007ffff0880971 in vtkDemandDrivenPipeline::ProcessRequest (this=0x55556086ea50, request=0x555560986600, inInfoVec=0x0, outInfoVec=0x55556089cff0)
at /home/glow/dev/paraview/pv1/src/VTK/Common/ExecutionModel/vtkDemandDrivenPipeline.cxx:176
#10 0x00007ffff09c99ae in vtkStreamingDemandDrivenPipeline::ProcessRequest (this=0x55556086ea50, request=0x555560986600, inInfoVec=0x0, outInfoVec=0x55556089cff0)
at /home/glow/dev/paraview/pv1/src/VTK/Common/ExecutionModel/vtkStreamingDemandDrivenPipeline.cxx:369
#11 0x00007ffff0881151 in vtkDemandDrivenPipeline::UpdateDataObject (this=0x55556086ea50)
at /home/glow/dev/paraview/pv1/src/VTK/Common/ExecutionModel/vtkDemandDrivenPipeline.cxx:353
#12 0x00007ffff08811b2 in vtkDemandDrivenPipeline::UpdateInformation (this=0x55556086ea50)
at /home/glow/dev/paraview/pv1/src/VTK/Common/ExecutionModel/vtkDemandDrivenPipeline.cxx:367
Could you open an issue on https://gitlab.kitware.com/paraview/paraview/-/issues ?
you mean that the file is not fully complete?
A XDMF expert would have to confirm that, but still, ParaView should not crash on any file.
