I have a linux workstation but paraview on it is extremely slow… I have no idea of why this happens but a difference of 100-150x is noted w.r.t. a normal laptop
Could you help me troubleshooting it?
Best regards
Best regards
What is slow? The UI? Rendering? Can you test a Python script to see if it is also affected?
Could you share a “benchmark” python script that can be useful to understand where the issue is?
The ParaView binary release form paraview.org/download comes with a small benchmark.
See the https://www.kitware.com/paraview-5-10-0-release-notes/
Also, please go to Help/ About, and post a screenshot. Is ParaView running in hardware rendering?
Alan
The test were performed but they are not so heavy hence were smoothly processed. I have issues for 3d files.
The about is:
Client Information:
Version: 5.11.0
VTK Version: 9.2.20230111
Qt Version: 5.15.8
vtkIdType size: 64bits
Embedded Python: On
Python Library Path: /usr/lib/python3.11
Python Library Version: 3.11.2 (main, Mar 13 2023, 12:18:29) [GCC 12.2.0]
Python Numpy Support: On
Python Numpy Path: /usr/lib/python3/dist-packages/numpy
Python Numpy Version: 1.24.2
Python Matplotlib Support: On
Python Matplotlib Path: /usr/lib/python3/dist-packages/matplotlib
Python Matplotlib Version: 3.6.3
Python Testing: Off
MPI Enabled: On
Disable Registry: Off
Test Directory:
Data Directory:
SMP Backend: Sequential
SMP Max Number of Threads: 1
OpenGL Vendor: AMD
OpenGL Version: 4.6 (Core Profile) Mesa 22.3.6
OpenGL Renderer: AMD Radeon RX 560 Series (polaris11, LLVM 15.0.6, DRM 3.49, 6.1.0-13-amd64)
Connection Information:
Remote Connection: No
I’m never used an AMD so I’m not enterely sure but to me it looks like the GPU is being used.
What should I do to use only CPU? May it be faster? I have 32 cores
