Dear all,
I enabled AutoMPI in ParaView using instructions given here: Paraview parallel - #4 by mwestphal . However, I am unable to open any new GUI after closing that session.
The log from the terminal is as follows:
$ paraview dummy.pvd &
[1] 9015
$ AutoMPI: SUCCESS: command is:
"/home/vachan/Downloads/ParaView-5.9.1-MPI-Linux-Python3.8-64bit/bin/mpiexec" "-n" "4" "/home/vachan/Downloads/ParaView-5.9.1-MPI-Linux-Python3.8-64bit/bin/pvserver" "--server-port=37369"
AutoMPI: starting process server
[1]+ Stopped paraview dummy.pvd
And then the GUI doesn’t pop-up. Is there anything else I should do? In the worst case, how can I switch off AutoMPI, now that the GUI is not showing?
Thanking in anticipation
Vachan
mwestphal
(Mathieu Westphal (Kitware))
June 14, 2022, 7:21am
2
Hi @vachan-potluri ,
AutoMPI is deprecated and unstable on moderm OS.
You should run our servers manually using mpi.
Just delete ~/.config/ParaView/*
best,
@mwestphal , thank you for the quick help.
One related issue. I have tried manually starting and connecting to a server as described here: 6. Remote and parallel visualization — ParaView Documentation 5.8.1 documentation . However, when I start a server in parallel, it exits with an error. The same error is printed n-1 times.
$ mpiexec -n 4 pvserver
Waiting for client...
Connection URL: cs://vachan-desktop:11111
Accepting connection(s): vachan-desktop:11111
( 0.126s) [pvserver ] vtkSocket.cxx:187 ERR| vtkServerSocket (0x19c92a0): Socket error in call to bind. Address already in use.
( 0.126s) [pvserver ]vtkTCPNetworkAccessMana:440 ERR| vtkTCPNetworkAccessManager (0x18968e0): Failed to set up server socket.
Exiting...
( 0.140s) [pvserver ] vtkSocket.cxx:187 ERR| vtkServerSocket (0x1f8b2a0): Socket error in call to bind. Address already in use.
( 0.140s) [pvserver ]vtkTCPNetworkAccessMana:440 ERR| vtkTCPNetworkAccessManager (0x1e588e0): Failed to set up server socket.
Exiting...
( 0.133s) [pvserver ] vtkSocket.cxx:187 ERR| vtkServerSocket (0xe142a0): Socket error in call to bind. Address already in use.
( 0.134s) [pvserver ]vtkTCPNetworkAccessMana:440 ERR| vtkTCPNetworkAccessManager (0xce18e0): Failed to set up server socket.
Exiting...
Further, if I launch pvserver on a single process, it doesn’t show any error. So it looks like pvserver cannot run on multiple processes.
I am using ParaView 5.9.1 (binary release) on Ubuntu 18.04. Is it that ParaView has to be manually compiled to use parallel capabilities?
Thanks again
mwestphal
June 14, 2022, 8:51am
4
How did you compile/install ParaView ?
I downloaded the precompiled binaries from here: https://www.paraview.org/download/ .
mwestphal
June 14, 2022, 10:08am
6
Are you using Windows, Linux or MacOS ?
mwestphal
June 14, 2022, 11:53am
8
Ok, make sure to use the mpiexec provided in the binary package.
./mpiexec -np 4 ./pvserver
This works, thank you very much!
