Paraview immediately crashing when opening Xdmf file
#1
I am trying to write a Xdmf-file from my tool for visualization in ParaView using the HDF5 format.
I initially created a VTK-file from my model and used Paraview -> File -> Save Data -> Xdmf Data File (*.xmf) to create a working combination of light and heavy data in Xdmf/HDF5. Now I am trying to reverse engineer the file from my tool. I am using the Java HDF5 library from HDFView to create my own HDF5 file.
When opening the Xdmf from the original VTK everything works fine and I see my model. However, when I open my self-written Xdmf/HDF5 file (File -> Open -> mesh.xmf) Paraview immediately crashes. Is there a log-file somewhere?
I did try to compare the two HDF5-files using HDFView but the values as well as Data Types seem to be identical. One difference is the maximum dimension size. In my case it is set to the actual dimension size, while the version created by ParaView has “Unlimited” as the “Max Dimension Size”. The only other differences are in the chunking and allocation time for HDF5. Could this be a problem for ParaView?
Can someone please give me a hint where the corruption of my files comes from?
I attached the two versions:
error.rar (189.7 KB)
working.rar (199.0 KB)
Edit:
I edited the HDF5 file to have the same chunking and unlimited maximum dimension size, just as the original. However, ParaView still crashes when reading my file.
error2.rar (196.4 KB)
Edit2:
I compared the two HDF5-files using VBinDiff. Although the values in the datasets seem to be identical, the structure of the two files seems to be different. Are there any guidelines how to create a proper HDF5-file for the other than the description in the wiki? Are there any preferences I have to set in the Java HDF5 library from HDFView?
#2
I digged a little deeper. Which IndexType and IndexOrder does the ParaView reader expect from the HDF5 file? Is this relevant?
Edit:
According to HDFView the Indexing Type and Order are equal in both files. So that can’t be it.
Edit2:
I used h5dump to create an ASCII representation of both HDF5 files. The data is identical. Same result for h5diff. However, the one written by ParaView is 820k and mine is 814k.
I noticed a slight difference in the headers:
This is the header from the working HDF5-file generated by ParaView:
HDF5 "working.h5" {
GROUP "/" {
   DATASET "Data0" {
	  DATATYPE  H5T_IEEE_F64LE
	  DATASPACE  SIMPLE { ( 17952, 3 ) / ( H5S_UNLIMITED, H5S_UNLIMITED ) }
   DATASET "Data1" {
	  DATATYPE  H5T_STD_I32LE
	  DATASPACE  SIMPLE { ( 89352 ) / ( H5S_UNLIMITED ) }
and this is the header from my file:
HDF5 "mesh.h5" {
GROUP "/" {
   DATASET "Data0" {
	  DATA {
   DATASET "Data1" {
	  DATA {
Notice the 2
	  DATA {
Any idea where these come from?
Edit3:
The difference in the header seems to come from working on my file. If I generate a clean new file, both headers are identical.
#3
I used h5debug to get some more information.
This is the result for the working file:
h5debug working.h5
Reading signature at address 0 (rel)
File Super Block...
File name (as opened):                             working.h5
File name (after resolving symlinks):              working.h5
File access flags                                  0x00000000
File open reference count:                         1
Address of super block:                            0 (abs)
Size of userblock:                                 0 bytes
Superblock version number:                         0
Free list version number:                          0
Root group symbol table entry version number:      0
Shared header version number:                      0
Size of file offsets (haddr_t type):               8 bytes
Size of file lengths (hsize_t type):               8 bytes
Symbol table leaf node 1/2 rank:                   4
Symbol table internal node 1/2 rank:               16
Indexed storage internal node 1/2 rank:            32
File status flags:                                 0x00
Superblock extension address:                      UNDEF (rel)
Shared object header message table address:        UNDEF (rel)
Shared object header message version number:       0
Number of shared object header message indexes:    0
Address of driver information block:               UNDEF (rel)
Root group symbol table entry:
   Name offset into private heap:                  0
   Object header address:                          96
   Cache info type:                                Symbol Table
   Cached entry information:
	  B-tree address:                              136
	  Heap address:                                680
and this is the result for my file:
h5debug mesh.h5
File Super Block...
File name (as opened):                             mesh.h5
File name (after resolving symlinks):              mesh.h5
Superblock version number:                         3
   Object header address:                          48
   Cache info type:                                Nothing Cached
The differences are in Superblock version number and Root group symbol table entry. Which version of the HDF5 library does ParaView 5.5/5.6 use?
#4
Ok, this seems to be it. I tried the whole thing with HDFView 2.13.0 and the included older HDF5 version. Using h5debug this generates:
h5debug mesh.h5
File Super Block...
Superblock version number:                         2
Which obviously still is not the same as from the VTK XdmfWriter, but it works. With Superblock version number: 2 I can open my model in ParaView 5.5 & 5.6.
For the sake of completeness the working file created from the HDF5Object package in HDFView 2.13.0:
Fixed.rar (196.3 KB)
