Hi, When trying to build a ParaView downstream application with the PV master branch, I run into the following error when calling ninja install in ParaView build dir:
Error message as below:
- CMake Error at cmake_install.cmake:323 (file):
file INSTALL cannot find “//Copyright.txt”.
FAILED: CMakeFiles/install.util
cd /Users/haochengliu/Kitware/cmb/buildDebug-cmb6-vtk-new-module/superbuild/paraview/build && /Applications/CMake.app/Contents/bin/cmake -P cmake_install.cmake
ninja: build stopped: subcommand failed.
➜ build vim cmake_install.cmake
<build-dir>/cmake_intall.cmakeLine 323:
- 322 if(“x${CMAKE_INSTALL_COMPONENT}x” STREQUAL “xlicensex” OR NOT CMAKE_INSTALL_COMPONENT)
323 file(INSTALL DESTINATION “${CMAKE_INSTALL_PREFIX}/share/doc/ParaView” TYPE FILE FILES “/Copyright. txt”)
324 endif()
After a quick grep through, I fail to find an easy fix. Ideas?
OSX Mojave + Apple LLVM version 10.0.0 (clang-1000.11.45.5) + CMake 3.12.0
