I tried to install ParaView-5.4.0 using the OpenFoam ThirdParty package of OpenFOAM 6, on Solus Linux. The installed Qt version is 5.11.1-26. I first reported the bug at OpenFOAM, and was asked to report the bug here as it’s ParaView & Qt version related. The latter is rather likely, as I installed the same version successfully some time ago when an earlier version of Qt was installed.
Error messages are (Fehler = Error):
[ 92%] Building CXX object Qt/Components/CMakeFiles/pqComponents.dir/pqCommandPropertyWidget.cxx.o
/home/klaus/OpenFOAM/ThirdParty-6/ParaView-5.4.0/Qt/Components/pqChangeInputDialog.cxx: In Konstruktor »pqChangeInputDialog::pqChangeInputDialog(vtkSMProxy*, QWidget*)«:
/home/klaus/OpenFOAM/ThirdParty-6/ParaView-5.4.0/Qt/Components/pqChangeInputDialog.cxx:81:45: Fehler: falsche Verwendung des unvollständigen Typs »class QHeaderView«
this->Internals->pipelineView->getHeader()->hide();
In file included from /home/klaus/OpenFOAM/ThirdParty-6/build/linux64Gcc/ParaView-5.4.0/Qt/Components/ui_pqChangeInputDialog.h:20:0,
from /home/klaus/OpenFOAM/ThirdParty-6/ParaView-5.4.0/Qt/Components/pqChangeInputDialog.cxx:33:
/home/klaus/OpenFOAM/ThirdParty-6/ParaView-5.4.0/Qt/Widgets/pqFlatTreeView.h:53:7: Anmerkung: Vorwärtsdeklaration von »class QHeaderView«
class QHeaderView;
/home/klaus/OpenFOAM/ThirdParty-6/ParaView-5.4.0/Qt/Components/pqChangeInputDialog.cxx:81:47: Fehler: falsche Verwendung des unvollständigen Typs »class QHeaderView«
class QHeaderView;
/home/klaus/OpenFOAM/ThirdParty-6/ParaView-5.4.0/Qt/Components/pqChangeInputDialog.cxx:83:45: Fehler: falsche Verwendung des unvollständigen Typs »class QHeaderView«
this->Internals->pipelineView->getHeader()->hideSection(1);
class QHeaderView;
/home/klaus/OpenFOAM/ThirdParty-6/ParaView-5.4.0/Qt/Components/pqChangeInputDialog.cxx:83:47: Fehler: falsche Verwendung des unvollständigen Typs »class QHeaderView«
class QHeaderView;
make[2]: *** [Qt/Components/CMakeFiles/pqComponents.dir/build.make:1310: Qt/Components/CMakeFiles/pqComponents.dir/pqChangeInputDialog.cxx.o] Fehler 1
make[2]: *** Es wird auf noch nicht beendete Prozesse gewartet…
make[1]: *** [CMakeFiles/Makefile2:11666: Qt/Components/CMakeFiles/pqComponents.dir/all] Fehler 2
make: *** [Makefile:130: all] Fehler 2
real 36m15,661s
user 233m10,983s
sys 25m44,645s
