I followed the steps in TTK - the Topology ToolKit - Topological Data Analysis and Visualization
to install paraview on Mac OS X Catalina. However, after installation, I’m running into the following issue whle trying to launch paraview:
Process: paraview [87962]
Path: /Applications/Applications/paraview.app/Contents/MacOS/paraview
Identifier: org.ttk.ParaView
Version: 5.8.1 (???)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: paraview [87962]
User ID: 501
Date/Time: 2021-04-14 17:45:10.416 -0700
OS Version: Mac OS X 10.15.7 (19H524)
Report Version: 12
Bridge OS Version: 5.2 (18P4346)
Time Awake Since Boot: 1600000 seconds
Time Since Wake: 640000 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @rpath/libpqApplicationComponents-pv5.8.1.dylib
Referenced from: /Applications/Applications/paraview.app/Contents/MacOS/paraview
Reason: image not found
Binary Images:
0x10c5be000 - 0x10c677ff7 +org.ttk.ParaView (5.8.1 - ???) <88887608-0F0F-304D-AF5A-9E9B5CBFFC0F> /Applications/Applications/paraview.app/Contents/MacOS/paraview
0x115ba1000 - 0x115c32f47 dyld (750.6) <326C6480-04F4-3164-A363-53079A148E2F> /usr/lib/dyld
Model: MacBookPro16,1, BootROM 1554.80.3.0.0 (iBridge: 18.16.14346.0.0,0), 8 processors, 8-Core Intel Core i9, 2.4 GHz, 64 GB, SMC
Graphics: kHW_IntelUHDGraphics630Item, Intel UHD Graphics 630, spdisplays_builtin
Graphics: kHW_AMDRadeonPro5500MItem, AMD Radeon Pro 5500M, spdisplays_pcie_device, 4 GB
Memory Module: BANK 0/ChannelA-DIMM0, 32 GB, DDR4, 2667 MHz, Micron, -
Memory Module: BANK 2/ChannelB-DIMM0, 32 GB, DDR4, 2667 MHz, Micron, -
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Oct 28 2020 14:13:29 version 9.30.357.42.32.5.48 FWID 01-767f6cce
Bluetooth: Version 7.0.6f8, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
PCI Card: pci11c1,5901, sppci_ieee1394openhci, Thunderbolt@194,0,0
PCI Card: Apple 57761-B0, sppci_ethernet, Thunderbolt@195,0,0
PCI Card: pci12d8,400e, sppci_usbopenhost, Thunderbolt@198,0,0
PCI Card: pci12d8,400e, sppci_usbopenhost, Thunderbolt@198,0,1
PCI Card: pci12d8,400f, sppci_usbehci, Thunderbolt@198,0,2
PCI Card: Apple 57761-B0, sppci_ethernet, Thunderbolt@70,0,0
PCI Card: pci11c1,5901, sppci_ieee1394openhci, Thunderbolt@69,0,0
PCI Card: pci12d8,400e, sppci_usbopenhost, Thunderbolt@73,0,0
PCI Card: pci12d8,400e, sppci_usbopenhost, Thunderbolt@73,0,1
PCI Card: pci12d8,400f, sppci_usbehci, Thunderbolt@73,0,2
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: FaceTime HD Camera (Display)
USB Device: Apple Thunderbolt Display
USB Device: Display Audio
USB Device: Hub
USB Device: USB 3.1 Bus
USB Device: Apple T2 Bus
USB Device: Composite Device
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 55.3
Thunderbolt Device: Thunderbolt Display, Apple Inc., 1, 26.2
Any way to fix this issue ?
