Hello, when I use mesh quality and then use histogram, what does its abscissa mean? The starting values of different models are different, some start from 1, some from 0. thank you!
In your first image, the absissa is the bin extents as defined in your histogram filter.
In the second screenshot, no idea, but you can take a look yourself by checking the “X array axis” in the properties panel.
Thank you. It seems that meshquality > threshold is better. The smaller the value is, the worse the mesh quality is?
It depends on the properties you choose on the mesh quality filter
OK, thank you very much!
