In order to load a gmsh .msh file into paraview on windows 10,
I followed instructions from https://github.com/nschloe/meshio,
and attempted to load new plugin paraview_meshio_plugin.py .
I tried using both the intel python interpreter, and the python 3.8 interpreter from the windows store.
I made a passing attempt to use pvpython.exe, but the -m option appears to not be supported, so I didn’t fully pursue this path.
Both attempts lead to the same error message:
“\?\C:\Users…\share\paraview_5.8\paraview-meshio-plugin.py is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support. Error status 0x000012f.”
Running ParaView version 5.81
python library path C:\Program Files\ParaView 5.8.1-Windows-Python3.7-msvc2015-64bit\bin\lib
Line-by-line analysis of the plugin, using the ParaView python panel, suggests that the plugin crashes upon import of the meshio python package, when the meshio __init__.py function imports __about__.py :
try:
# Python 3.8
from importlib import metadata
except ImportError:
import importlib_metadata as metadata
I’ve looking into it and removing importlib would be too intrusive for meshio. I don’t think jsonschema is the problem either. Without an error message, it’s hard to tell.
Apologies for not fully reporting the error message earlier.
Python 3.7.4 (tags/v3.7.4:e09359112e, Jul 8 2019, 20:34:20) [MSC v.1916 64 bit (AMD64)] on win32
>>> from paraview.simple import *
>>> import meshio
File "C:\Program Files\ParaView 5.8.1-Windows-Python3.7-msvc2015-64bit\bin\Lib\site-packages\meshio\__about__.py", line 3, in <module>
ImportError: cannot import name 'metadata' from 'importlib' (C:\Program Files\ParaView 5.8.1-Windows-Python3.7-msvc2015-64bit\bin\lib\importlib\__init__.py)
During handling of the above exception, another exception occurred:
File "<console>", line 1, in <module>
File "C:\Program Files\ParaView 5.8.1-Windows-Python3.7-msvc2015-64bit\bin\Lib\site-packages\meshio\__init__.py", line 1, in <module>
from . import (
File "C:\Program Files\ParaView 5.8.1-Windows-Python3.7-msvc2015-64bit\bin\Lib\site-packages\meshio\_cli\__init__.py", line 1, in <module>
from ._ascii import ascii
File "C:\Program Files\ParaView 5.8.1-Windows-Python3.7-msvc2015-64bit\bin\Lib\site-packages\meshio\_cli\_ascii.py", line 5, in <module>
from .. import ansys, flac3d, gmsh, mdpa, ply, stl, vtk, vtu, xdmf
File "C:\Program Files\ParaView 5.8.1-Windows-Python3.7-msvc2015-64bit\bin\Lib\site-packages\meshio\ansys\__init__.py", line 1, in <module>
from ._ansys import read, write
File "C:\Program Files\ParaView 5.8.1-Windows-Python3.7-msvc2015-64bit\bin\Lib\site-packages\meshio\ansys\_ansys.py", line 10, in <module>
from ..__about__ import __version__
File "C:\Program Files\ParaView 5.8.1-Windows-Python3.7-msvc2015-64bit\bin\Lib\site-packages\meshio\__about__.py", line 5, in <module>
ModuleNotFoundError: No module named 'importlib_metadata'
Second, I downloaded source, and added a couple of packages to C:\Program Files\ParaView 5.8.1-Windows-Python3.7-msvc2015-64bit\bin\Lib\site-packages
package importlib_metadata, extracting a directory from https://github.com/python/importlib_metadata/tree/master/importlib_metadata
package zipp, placing into a directory the contents of https://github.com/jaraco/zipp
At that point ```import meshio`` executed without complaint in the ParaView python window.
However attempting to load the plugin generates error messages:
Generic Warning: In C:\bbd\8fbebceb\build\superbuild\paraview\src\Remoting\ServerManagerPython\vtkPVPythonAlgorithmPlugin.cxx, line 187
Failed to load Python plugin:
Failed to call `paraview.detail.pythonalgorithm.load_plugin`.
File "C:\Program Files\ParaView 5.8.1-Windows-Python3.7-msvc2015-64bit\bin\Lib\site-packages\paraview\detail\pythonalgorithm.py", line 509, in load_plugin
spec.loader.exec_module(module)
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "C:\Program Files\ParaView 5.8.1-Windows-Python3.7-msvc2015-64bit\share\paraview-meshio-plugin.py", line 14, in <module>
paraview_plugin_version = meshio.__version__
AttributeError: module 'meshio' has no attribute '__version__'
ERROR: In C:\bbd\8fbebceb\build\superbuild\paraview\src\Remoting\Core\vtkPVPluginLoader.cxx, line 524
vtkPVPluginLoader (000002BB6EF08F90): %1 is not a valid Win32 application.
Yes ! you are right that the first code example should begin with try:
I have the idea that it has to do with python packaging, but I don’t know what to make of the clues.
The readthedocs site for importlib_metadata (https://importlib-metadata.readthedocs.io/en/latest/) posts a release note:
## v2.0.0
2020-06-26
* `importlib_metadata` no longer presents a `__version__` attribute.
Consumers wishing to resolve the version of the package should query it directly
with `importlib_metadata.version('importlib-metadata')` . Closes #71.
Since pip is not available for ParaView python, I downloaded source and moved the appropriate code to site-packages by copy-paste. There may be an important step missing, which pip would normally perform.
