I’m using pvpython to render and start an animation from the command line.
This is my script without the used filters, which I created from a trace.
# myscript.py
# trace generated using paraview version 5.10.0
#import paraview
#paraview.compatibility.major = 5
#paraview.compatibility.minor = 10
#### import the simple module from the paraview
from paraview.simple import *
dd00 = CSVReader(registrationName='dd00*', FileName=[...])
# get animation scene
animationScene1 = GetAnimationScene()
renderView1 = FindViewOrCreate('RenderView1', viewtype='RenderView')
# update animation scene based on data timesteps
animationScene1.UpdateAnimationUsingDataTimeSteps()
# Apply some filters to data
animationScene1.Play()
Interact()
If I now run this script with pvpython myscript.py the rendered view pops up and the animation starts, but if I try to interact with the view while the animation is running, the view will freeze until the animation is done. Then I can interact with the view but I can’t reset or start the animation.
Is there either a way to start the animation from the Interactor? Or to start the animation in a non blocking way?
Thanks in advance!
