ParaView does not open a window, but runs as a background process.
Tried different versions of the program, from old to new.
Tried various compatibility settings.
Tried installing older graphics drivers.
Nothing helped.
It opened before, but then I didn’t use the program for several months. Now there’s a problem.
I couldn’t find a solution, maybe I didn’t search well. I apologize in advance.
I don’t mean the installer file, there are no problems with the installation. There is a problem that the installed program isn’t launch.
Even if it’s installed on the USB flash drive.
I can use it on a virtual machine, but it’s necessary to find out why it does not work for the main OS.
Have you had paraview installed before? If you start from the cmd line, “paraview.exe --dr” does it start? (This ignores the settings file.)
If so, you can use the preferences menu to reset to the default settings, and you should be able to start.
Hi, I searched up your post because I had the same problem as you. For me it seems like it’s a problem about how much RAM my pc is able to allocate to Paraview and if there isn’t enough Paraview just stays in the background without starting. For now I just have to kill some background processes that clog up the RAM and it seems that it launches as normal.
